This means the system is OFF... I swapped the switch and unplugged/re-plugged the harness to the ABS Module.
The little I did find in searching suggested a broken wire somewhere in that harness but I never found a resolution.
Is this the likely culprit?
Two things have caused this on mine in the past
Leak from hydro unit running along the outside and down into the wire connector
Wheel sensor gone bad
1993 BMW 540i
Check the ASC motor and cable. The system runs the motor at startup and if the extend/retract signals aren't present the ASC light will turn on.
demet
I know my cruise control isn't working.. have another unit to install so can check these then.. Thanks for the idea.
I like having the ASC working in snow... gives me a heads up when I'm sliding with that grab and I can adjust when otherwise I might not notice until its too late.
