Results 1 to 17 of 17
Thread: e39 tuning. What do you guys recommend
    Sep 2018
    Jacksonville Illinois
    2000 bmw 540I 6-speed
    I have an e39 540i. I'm looking to get a little more performance out of it. I have done some research on CAI's and exhaust modification, however I am completely clueless on the actual tuning front with this car. to clarify I have owned American cars and have tuned them (with various tuning softwares and tuners) nut I'm not sure the dos and don'ts of the BMW brand. any help you can provide me with this would be greatly appreciated
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    moved to E39 forum from 5 series general
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Your going to pay a LOT of money for any BMW performance part and then a tune for very little gain that you can actually feel.
    Your first mod should be a 3.15 diff, LSD from an M5 or just a pegleg 3.15 from a 540iA.
    The only real mods that a real gear head would enjoy would be a supercharger, nitrous, or turbo. Turbo being the hardest to put in.
    Good luck.
    Jun 2010
    Bay Area, California
    325iT, 540iT
    Good luck.
    Weight reduction too. Sawzall the damn thing and make a ute. Fun for the whole family.
    JimLev's Avatar
    Sundance Mesa, NM
    Quote Originally Posted by blarf View Post
    ^-right, open chassis should drop a 1000 lbs.
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    You can get a more peppy feel with a retune. It basically remaps the throttle curve and some other minor tweaks. It will not yield any major gains in peak horsepower though. Contact dudmd on this forum. He seems to have the most knowledge of tuning these cars and can send you a tune via email that you can load in.
    Some decent gains can be had by changing to the pre-TU non-vanos intake manifold. They are cheap and give some increase up top in the rpm bands with just some minor losses in low end torque. Junk yard part that is pretty easy to find. Removing the restrictive exhaust manifolds with those pre-cats helps too, but that ups the costs if you go headers. Some just hollow out those pre-cats, to help the engine breath a bit more. A re-tune after those hardware changes will give something noticeable, but still not huge. To get big gains, you need to drop some big bucks on a SC kit.
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    ^^^ all what the guys said. This is an old topic for n00bz to ask about. Headers are worth it but typically very expensive, retrofitting intake manifold from older cars is worth it, diff is a huge upgrade for real-driveability even if its not "ENGINE TUNED" sexy to talk about.
    As philly says, the available 'tunes'are more of a 'feels faster' than 'is faster'... but then again - as I used to say about the Shark Injector - even if it doesn't really make power, if you like how the car drives better, what the helll maybe its worth it.
    might add - in the "FAQ" department - "no you can't get cams for it"...
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Sep 2018
    Good luck.
    long term goals is some form of boost (would love a roots style blower but haven't found anything yet). what diff comes factory in these cars and will I be replacing the entire Dif or just the ring and carrier?
    lol I figured I would catch some flack about the question however you never learn anything if you never ask questions.
    Mar 2010
    No worries.. Appreciate the understanding, normally the kiddies get these "less than super cheap and easy fun" answers and say "BUT NO WAY MAN YOU GUYS JUST ARE ALL LAME AND I AM SUPER BALLAR AND I'M GONNA FIND A WAY TO MAKE IT WORK..."
    Re: the diff, you have an open diff now, and to sort that, you have several routes.
    1. You can go torque-biasing LSD - WaveTrac, Quaife, "Mfactory". Suboption 1.A. is you can get the core and swap it into your existing case yourself (philly did), Suboption 1.B. is you can buy one all built (I did... diffsonline is local to me and connected to friends of mine...)
    2. You can swap an M5 LSD diff in - traditional clutch-based.
    If you go #1 then you just keep all your axles & driveshaft. If you go #2 you need to swap the DS, and either the axles for M5, or axle-flanges at the diff. Search around here there's LOADS of threads explaining it.
    For non-centrifigual blowers, search around for the "Toolman2" posts - he makes adapter kit to fit junkyard blowers. Its not a real "plug and play kit" ala Dinan or VF etc. as much as it is a "DIY-guy kit with the most important custom parts assuming you can sort the rest out". "Wagons Ho" is also working on a product/solution but slow-and-steady in his development so that's been in the works for years without a commercially viable product quite yet.
    If you want some amusement go dig up the "deadpool" thread for all the successful and failed efforts to boost these motors...
    2003 M3CicM6 TiAg
    Former:
    San Jose, CA
    1997 BMW 540i 6 speed
    There's always a Chebbie V8...
    Sep 2018
    Quote Originally Posted by edjack View Post
    was quite hoping to keep it all bimmer lol. just the unique factor of a roots blower is appealing to me. lots (relative to the boosted bimmer world) of people do turbos or "pro-chargers" and I don't like doing the same thing as everyone else.
    Nov 2011
    Greedland
    99 540i6, 02 X5, Tundra
    There is this option,
    E85 fueled, Eaton m112 supercharged 4.5L M62TU, TTV racing flywheel, Spec stage 2+ clutch, 88c thermostat, eibach sway bars, wavetrac 3.15 lsd, m5 steering box, Quantum 340lph fuel pump, Dinan camber plates, some powerflex bushings, Supersprint headers, M5 cats, 2001 gas pedal upgrade and many other things done. all diy by me
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Quote Originally Posted by 1999 540i m View Post
    Oooh. Range Rover supercharger?
    Nate J.
    (oOO\ (|||)º(|||) /OOo)
    (eŌō\ (||||)º(||||) / ōŌe)
    Nov 2011
    Greedland
    Quote Originally Posted by computiNATEor View Post
    Jaguar, but very similar
    Mar 2010
    For benefit of da n00bz0rz - 99540iMMZZZ is an example of Toolmans 'starter kit' being built up into a full motor. "All" of the Toolman builds (not sure how many are rolling these days but 3, 4... 6? Toolman?) tend to be a little different because of choices with engine managment or other... 99540iMmmmz refreshed his motor inside for instance.. lightly bored...
    Speaking of which... Your homeboy homebrew honejob seems to be working working great, eh? Assuming so that's good to know...
    2003 M3CicM6 TiAg
    Former:
    DeWitt, Michigan
    '97 540i/6, '97 328i
    +100!
    Nov 2011
    Greedland
    Quote Originally Posted by tptrsn View Post
    +100!
    Update thread coming soon, I have 100 lbs of stuff coming from clemster
  1. What spark plug you guys recommend for AA stage I+ 95 M3?
    By madsedan in forum Forced Induction
    Last Post: 01-28-2003, 11:24 PM
  2. What kind of tires do you guys recommend?
    By LeVik in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 01-20-2003, 10:46 PM
  3. My Fikse FM-10s have become oxidized...what do you guys recommend?
    By Amir in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 12-27-2002, 01:48 PM
  4. Which BMW repair manual do u guys recommend?
    By M3Jokster in forum 1992 - 1999 M3 (E36)
    Last Post: 09-05-2001, 10:16 PM
  5. Can you guys recommend a place to buy clear corners?
    By Jorge in forum 1991 - 1999 (E36)
    Last Post: 05-20-2001, 07:31 PM
