Page 2 of 2 FirstFirst 12
Results 26 to 43 of 43
Thread: 210mm diff questions for E36 fitment - when is a 210 not a 210?
  1. #26
    Toronto, Canada
    E36 Turbo
    Quote Originally Posted by wanganstyle View Post
    The local Bay Area junkhoarders are selling them for $1200 on Craigslist.
    A new Lsd unit from wavetrac retail is only $1395 for the 210mm
    Certainly the prices have gone up over the years abut that's a little excessive IMO for a part that will need to be rebuilt.
    Re. diff, I'd be just fine with a fresh rebuilt stock LSD/diff. No fancy diff needed.
    anyways, it seems this thread has gone off course from it's original intention. No one can confirm what exact diffs are 100% compatible other than the E32 750il and E34 M5 diffs and no one seems to want to/can verify that other "large case" differentials like 540 diffs are not internally the same.
  2. #27
    Dec 2007
    SF bay area
    1998 M3 / 2000 S2000
    Quote Originally Posted by NOTORIOUS VR View Post
    Bmw parts counter will sell you a new one if not nla.
    Wanganstyle Powertrain
    http://www.wanganstyle.com/
    S54B32 E36 M3 DTA S100 Sedan Street car full swap:
    http://forums.bimmerforums.com/forum....php?t=1437471
  3. #28
    Toronto, Canada
    E36 Turbo
  4. #29
    Mar 2008
    West Covina, CA
    97 M3/4/5, 98 M3/2/5
    I'll check out the local picker junk yard when a E34 540 shows up but im pretty sure it will be the same diff as an open E32 740/750
  5. #30
    Vancouver, B.C., Canada
    '97 M3
    If you needed to rebuild the diff anyway it would be nice to know what parts from which diffs would work to build one that works for our purposes.
  6. #31
    Toronto, Canada
    E36 Turbo
    Quote Originally Posted by tofunin View Post
    Would be interesting to know for sure, this as I've been told is not the case.
  7. #32
    Mar 2008
    West Covina, CA
    So from what I have seen and re-read from my previous research they're pretty much the same casing only difference is the input flange and the VSS connector.
    https://www.bimmerforums.com/forum/s...nger-Available
    https://www.bmwfanatics.co.za/showthread.php?tid=1374
    http://www.bmwe34.net/E34main/Mainte...fferential.htm
  8. #33
    Toronto, Canada
    E36 Turbo
    I've seen and read all of the pages I could find (including the ones you just posted), and you're right externally they all look identical except for small differences like the input flange, VSS, mounting points on the case, cover, etc.
    Unfortunately internally is where they are said to be different... if you look at my OP you will find that the LSD is even a different part number. This leads me to believe there might be some truth to the internals being different in some way. If they're physically smaller (and/or weaker) or just not interchangeable that I do not know.
    The only way to know for sure is if someone has access to the diffs and takes them apart to compare side by side.
  9. #34
    Dec 2007
    SF bay area
    Iirc I shipped butters a 2,93 210mm gear quite a while back.
    210mm diff with 2,93 Lsd oem
    Doesn’t exist in the USA as shipped in a car from the Bmw factory commonly.
    This having been said there is a E34 540i running around with a 2.82 Lsd in the Bay Area, a E34 with a 2.93 Lsd, a 850 with a 2.93 Lsd.......I may have been involved with this Frankensteinization.
    If you want a e32/34 210mm in 2,93 with LSD that uses the rally road kit to bolt into a e36 You gotta build it sorry;
    1994/5 E34 540i 6mt msport has an open diff; I have built an Lsd for one well known forum members car (abl imports)
    The E34 540ia msport has an open diff. Have one in local friends shop now. The Bmw factory did build a 2.65 Lsd; it came
    Oem in a very common e31 model; 850csi. Perhaps option on some 850-6mt.
    Local friend has one 850csi in his shop
    This post and prior above should explain it all; was involved in various local random friend project Frankensteins
    There is a local E34 540ia with m variable Lsd from e92m and 2,93 changed to 3.15 from a e34m5
    There is another local E34 540i-6mt running around with original 2.82 and e92 m variable differential.
    There is also a local e31 with 2.93 and e46 m variable Lsd running around.
    Everything was customized; multi generational gathering of players style
  10. #35
    Toronto, Canada
    E36 Turbo
    Honestly dude, you're not adding anything informative to this thread what so ever and certainly not actually answering the questions in the OP. You're posts explain exactly ZERO, so not sure if you're just trolling or just here to make noise.
    There is no question that you can make other parts work in other diffs, but unless you're actually going to come up with a list of interchangeable parts I don't understand what you're doing right now. You said in your PM to me that you don't want to help with DIY stuff, so why are you here? Just to advertise?
  11. #36
    Dec 2007
    SF bay area
    Read prior two statements and your original question can be answered. Don’t need to ask for spoon feeding as we are all adults and should be able to read between the lines as done in professional life at work.
    This is a public forum and posting is open to all.
  12. #37
    Toronto, Canada
    E36 Turbo
    Don't be daft. Nothing YOU have said is related to what my OP is about. I'm asking for the community to help with my question, what you've posted so far isn't any help. You obviously don't want to be a part of the community (you said so in our Facebook chat) and your posts reflect that.
    That's generally something people say when you're caught with their pants around their ankles.
  13. #38
    Dec 2007
    SF bay area
    Are you often caught on your knees?
    ***you are still not reading the obvious data point answering your question***
    Above statement as I would repost to a noob;
    3,15 from e39 m5 = direct interchange to the place of original 2,93 from 34 540ia open.
    To the even more noob sauce I’d spoon feed some more
    Open unit from 540i-6 direct interchange with m variable from e46m/92m/60m
    The same housing will bolt
    Into a e31 and can also take a m variable Lsd or open or clutch type. Ain’t care
    I don't give away time as a consultant for $0 nor support DIY projects for free; but Misinformation is not ok
    the housing of the E28/24 M5 M6 cars and the E32 740/750 v8/v12 cars and the housing of basically every single other 210mm traditional unit between e23-e60 generations is the same
    the gears interchange,
    clutch type lsd units interchange internal parts but have 3 different series
    the early 210mm clutch type LSD is from E28/24 and e23 7 series era
    the middle revision is from e34/32
    the late version is in e34 m5 late model, e39m and e36 3.2 euro evo
    the m variable also has 2 series, gen 1 and gen2; these unit were OEM equipment in the E46M3 and e60M5 and e92M3
    gen 1 was in early 46m, gen2 was in late. Gen one can be taken apart and inspected for damage, gen2 is sealed but seems to be more robust.
    both would be a good inexpensive street option for a LSX swap car needing a 210 conversion and inexpensive LSD for drag racing; just buy a complete e46m3 donor and a e32/34 540/740i open 2.93 as they are the cheapest
    one could build a 210mm e32/34 3.64 m-variable LSD (from any 46m/60m/92m) unit dirt ass cheap style for drag racing/drifting into a wall
  14. #39
    Apr 2006
    Minnesota eh?
    86 325es
    Sometimes you just have to buy some stuff and figure it out.
  15. #40
    Toronto, Canada
    E36 Turbo
    Now that is what I'm talking about, would have been easier just to give these points from the beginning. The extra detail paints a clear picture that large case = large case and internally large case stuff can be swapped around.
    As you say misinformation is NOT ok and I agree with that 100%. There seems to be plenty of confusion and lack of info that leads to misinformation unfortunately. I'd like to thank you for your info/input!
    You're right, but fringe access to parts makes that difficult for some and with just some basic info/clarification which seems to have come up now (above) makes the risk less pronounced to just throwing money away. I have no problem releasing my findings, I'm just here to learn and enjoy my car. But certainly for the amount of people who run 210mm diffs, the info is really lacking as a community.
  16. #41
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    What is the story with 215mm diffs?
  17. #42
    Dec 2007
    SF bay area
    What’s 215mm?
    There is 188k and 215k
    Those are both compact and completely different standards than 188mm and 210mm
    If you are talking about case bearings this is complete irrelevant to the e36 application;
    The e92m pinion bearings are same as 215k e92 335 and e38 215k
    The e92m uses a 210mm Lsd and gear and side bearings; it’s an m car still.
    The bigger 215k pinion bearing set is non interchange with older 210mm Diffs; they also are plastic double roller ball bearing style and not sold by Bmw; the e92 crowd is stuck with these and will be paying dearly for it long term.
  18. #43
    Jul 2012
    Tucson
    1994 BMW e36 conv.
    https://metricmechanic.com/wp-conten...ferentials.pdf
    I have no personal experiences with Metric Mechanic, but enjoyed the info and wanted to add to this dormant conversation.
  1. 17" V710 E36 fitment question.
    By techno550 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 04-21-2006, 11:47 AM
  2. E36 and E30 diff questions
    By weaksauce in forum 1992 - 1999 M3 (E36)
    Last Post: 03-22-2006, 08:08 PM
  3. quick e36 fitment question...
    By 325isracer in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 12-18-2005, 01:07 AM
  4. Wheel Fitment Question For E36's
    By jtc08 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 11-08-2004, 07:49 PM
  5. Fitment question for E36 M3
    By Jon97 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 11-29-2002, 02:46 AM
