Results 1 to 7 of 7
Thread: Help With E38 Brake Bleeding Procedure! Seriously?
    Feb 2015
    Kuna, Idaho
    Too Many Cars (NOT!)
    The Car: 1998 750iL (Pre-Facelift) 120K miles
    I bought it cheap and knew it needed brakes, so literally did it all!
    Replaced:
    Master Cylinder
    Rotors (Front and Rear)
    Pads (Front and Rear)
    Rebuilt Calipers
    Installed SS brake lines
    All that went great, it's the bleeding that's killing me.
    Checked the TIS and it says:
    Pressurize the master cylinder to 29psi (I have a Motiv pressure bleeder)
    Start with right rear, run "Bleed" procedure in GT1 (which fires up the ABS pump)
    Carefully pump the pedal (do not exceed the stop)
    Close the bleed screw
    Move on to the left rear, then right front and finally left front. Rinse and repeat...
    I have put somewhere in the vicinity of 5 gallons of DOT 4 brake fluid through this system and still cannot get clear bubble-free brake fluid out. I can't be the only guy who has had to change a master cylinder in one of these things, allowing a butt-load of air into the system. Gimme a break! I did this same job with my 850 E31 and had no problems at all.
    Does anybody know if there is some kind of "trick" to this, because I'm really sick and tired of bleeding brakes. It's pretty much all I've done for a friggin' week.
    Help!
    Mike Drives:
    BMW's
    E24 - 635CSiA - (1) 1985 (US)
    E24 - 635CSi - (1) 1985 (EC)
    E31 - 850iA - (1) 1991 (Black)
    E31 - 850iA - (1) 1991 (Calypso Red)
    E32 - 740iA - (1) 1994
    E32 - 750iA - (1) 1990 (Not an "L") (EC German National)
    E32 - 735iL - (2) 1990
    E32 - 750iL - (1) 1990
    E38 - 740iLA - (2) (1) 1997 & (1) 1998
    E38 - 750iLA - (1) 1998
    E38 - 740iA - (1) 2000 "Short Sport"
    E39 - 528iA - (2) - 2000 & (1) 1997
    Also:
    2015 Ram 3500 Dually, Cumins 6.7, Std.Cab. Long box 4x4 (To haul all this junk when necessary)
    2014 Dodge Dart Rallye (Daily Driver)
    2007 Mercedes Benz CL600 (Brabus SV12S)
    Mercedes Benz SL's - (1) (2002) & (1) 1999 500 - (1) 1999 600
    1967 Buick Riviera (2)
    Feb 2015
    Kuna, Idaho
    Really! Are you all telling me that either no one but me has had to bleed E38 brakes, no one has ever had this problem or I'm doing everything right.
    Please let me know which it is, so I can stop bleeding brakes!
    Mike Drives:
    BMW's
    Also:
    Aug 2018
    NJ
    E38, b4 tdi
    This is from my experience while at vw. After the abs and pressure bleed, sometimes we did have to do it with a second person to force the final air out. And it was always one wheel, just a but of foam between us and flagging good time haha. Our pressure bleeder towards the end of its diaphragm life would get weaker and weaker needing to just bleed without it until our foreman would replace it
    Sent from my VS501 using Tapatalk
    Nov 2017
    DFW
    1999 740iL
    Are you getting bubbles at all four corners or just one? Do you have good threads at each bleed nipple? I've had a situation before where I was pulling air through the nipple threads and could never get clean fluid. Wrapped the threads in teflon tape and problem went away.
    Other than that, I've got no new insight.
    Feb 2015
    Kuna, Idaho
    Thanks for the reply's!
    Yes, the bubbles are coming from all four wheels. I'm really stumped! I may have to employ the 2 person method just as a final push. Other than that, I don't have a clue.
    Thanks again
    Mike Drives:
    BMW's
    Also:
    Feb 2015
    Kuna, Idaho
    Update;
    Finally! No more bubbles! All it took was 28 hours of continuous bleeding running both preload pumps alternatively, the ABS pump and pumping the pedal.
    I never want to do that again!
    Mike Drives:
    BMW's
    Also:
    Aug 2018
    Miami
    2001 BMW 750il
    Quote Originally Posted by masbury View Post
    Thanks again
    That is crazy bro.... what happen?
  1. Correct brake bleeding procedure with ASC+T?
    By dragon850 in forum 8 Series (E31)
    Last Post: 04-18-2018, 02:11 PM
  2. Brake bleeding procedure?
    By MN2K740i in forum 1995 - 2001 (E38)
    Last Post: 09-15-2015, 10:01 PM
  3. Need Help With E38 Brake Issues Please
    By dudewith95E38 in forum 1995 - 2001 (E38)
    Last Post: 07-01-2013, 02:14 AM
  4. E34 Brake Bleeding Problem, Help!
    By Bodgit in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-10-2004, 07:24 PM
  5. HELP - Brakes bleed twice and still MUSH!!
    By ///Mracer in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 11-25-2002, 12:24 AM
