Results 1 to 11 of 11
Thread: front spoiler lip material
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    I have the original E36 M3 front lower lip spoiler 51112251767 installed, this one https://www.ecstuning.com/b-genuine-...r/51112251767/ and that has some minor scratches, nothing broken or cracked, but some scratches on the outside of 1-2mm depth on 2 areas, so more a cosmetic repair is to be done.
    What is the original spoiler material?
    What kind of bumper putty to use best to fix minor scratches for this spoiler material?
    Most of the bumper putties exclude some kinds of materials, example: "The BUMPER FIX putty is a putty for levelling the surface of plastic parts, e.g. bumper fascias, rear view mirror housings, strips and mudguards. The product has a very high elasticity and excellent adhesion to most plastics (except for polyethylene (PE) and Teflon (PTFE) ). It also has good adhesion to polypropylene (PP) which enables application on non-primed surfaces."
    Jan 2003
    USA
    BMW M3
    Might be better to sand it and then sand with finer paper, apply forever black or such after.
    Jan 2005
    Japan
    Thanks, that is even easier then with just sanding and painting, I have a OEM spoiler lip new on stock, but the original one just has some small scratches and that would be waste of money to scrap it now because of some scratches and such a repair does not take too much time. I like to repair if possible, makes fun.
    Someone knows the material of the spoiler lip?
    Just in case in future I have a larger damage on the front lip. Have successfully repaired the spoiler on my E32 750iL, which had a large crack, for that I used fibre glass repair kit and a plastic welding kit.
    the crack on the E32 locked like this almost 10 years ago http://www.bilder-speicher.de/image_...08050600346923
    final result and still o.k. after 10 years http://www.bilder-speicher.de/image_...08060707671210 http://www.bilder-speicher.de/image_...08060707912336
    RRSperry's Avatar
    RRSperry is offline Senior Moment Member BMW E36 M3 Expert
    Mar 2002
    Eldersburg, Md
    95 ///M3sc, '21 C8 HTC
    S.E.M MINI-MAX™ BUMPER REPAIR Part #68422
    Then I'd actually Plastidip it...
    Jan 2005
    Japan
    Thanks, will get that for the next repair for the spoiler lip, that is always in danger on our M3's. Already sanded the small scratches today and applied bumper and trim paint, not a perfect fix, but acceptable. Next time a repair is necessary I will use that stuff.
    quote: Mini-Max™ Bumper Repair Part #68422, Mini-Max™ Bumper Repair is a two-component, epoxy-based filler for repairing small damage to bumpers and rigid or semi-rigid plastics. Features: No adhesion promoter necessary, Superior adhesion, Excellent sanding and feather edge, Does not shrink or pinhole, Zero VOC. Properties: 1 oz. cartridge, Gray, Working time: 5 min, Sand time: 15 min, Top coat time: 20 min, cure time: 1 hr.Applications: Olefin-based plastics, Rigid and semi-rigid plastics
    Feb 2002
    Honolulu, Hawaii
    1997 M3, 2dr/5spd*
    You could also vinyl wrap it...the guy I sold my car to, and bought it back from, did this in flat black and it looks good.
    Estoril/Modena '97 M3...sold for the second time.
    You only live once, and I'm running out of time...
    Jan 2002
    outta SoCal, now CO
    '98 M3 Alpine White
    It's a semi-rigid plastic, probably ABS. Used to use 3M Duramix 4040 on bumper material like that but they discontinued the stuff. Too bad. Tougher than nails and bond/cures in about 3 minutes. Looks like the replacement is 3M 04240. The drawback is you need the applicator that squeezes the 2 part stuff from the tubes and mixes it in the applicator tip. It can probably be mixed manually. Expensive but worth it. Sounds very similar to the Mini-Max stuff mentioned a couple posts back.
    See ya later,
    tony
    '98 M3, '92 Dinan3, '05 R1100S BCR, '07 R1200S, Aprilia T
    Jan 2005
    Japan
    ABS seems to be relatively easy to handle when it comes to repairs. When I have cracked plastic parts I either use fiber mats and epoxy and/or a plastic soldering iron, have an assortment of plastic welding sticks for ABS, PP, PVC, PE and various shapes of soldering iron tips.
    Here is a good demo on an Rover bumper: rear-bumper-soldering-abs-plastic-repair http://pixels1.com/cars/cars/rover-8...ic-repair.html
    Mar 2014
    Sammamish, WA
    1998 M3/4/5
    There seems to be some kind of "coating" on it, which gives it some gloss. My original one had this pealing in several sections and it looked bad. I just bought a replacement. At less than $100 it seemed like the easiest solution.
    1998 Titanium/Dove M3/4/5
    2020 Toyota 4Runner
    Dublin, OH
    '95 M3, '17 Civic Si
    ABS is a bit brittle for such a location. My guess is polypropylene (PP), but I'd have to look at the part's imprinted sign to know. Plastics will always have an imprinted material callout on them.
    All that said, BMW does love their ABS so I wouldn't be shocked at all if it was ABS. ABS also tends to be shinier than PP
    -Rich-
    Sep 2016
    Charlotte, NC
    1995 BMW M3 Coupe
    If you really must know try removing the lip. Most parts when injection molded have the material type inscribed into the mold. ABS, PC, PC-ABS, PA66, PA66GF, POM, PP, PE etc.
  1. WTB: Reiger Front Spoiler Lip
    By Bimmer325 in forum BMW Parts Wanted
    Last Post: 01-10-2004, 03:42 PM
  2. Front Spoiler Lip Extensions
    By PWJK12 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-14-2003, 12:03 AM
  3. WTB Front Spoiler Lip for E36 non-M3
    By Franchise in forum BMW Parts Wanted
    Last Post: 05-27-2003, 04:28 PM
  4. Front spoiler lip attachment screw question
    By M3 Pete in forum 1992 - 1999 M3 (E36)
    Last Post: 03-11-2003, 02:41 PM
  5. FS: E36 M3 Rieger Front Spoiler Lip by Rieger
    By riegeretc in forum BMW Parts For Sale
    Last Post: 02-27-2003, 12:39 AM
