Or would it be no different on a stand? Seems like maybe I should get it started before it’s out of the car. At this point everything is detached except the driveshaft and maybe a connection or two I haven’t found yet. Top side is ready to go.
Depends on your stand and mounting. If “loose” then no; it “tight” then okay.
Advantage of in place: vehicle mass is counterbalance.
Advantage of out: don’t have to worry about something damaging the body if it slips.
2001 750iL DD74441
Stock
RIP: 2003 540iA Sport GS56111
H&R front springs, Ultimate Cup Holder, Euro Dash & Armrest, Grom, BavSound Stage1
I like my method,
E85 fueled, Eaton m112 supercharged 4.5L M62TU, TTV racing flywheel, Spec stage 2+ clutch, 88c thermostat, eibach sway bars, wavetrac 3.15 lsd, m5 steering box, Quantum 340lph fuel pump, Dinan camber plates, some powerflex bushings, Supersprint headers, M5 cats, 2001 gas pedal upgrade and many other things done. all diy by me
Yes, absolutely if you intend to dismantle the engine. If you have a super duper impact then no but for those of us relegated to hand tools, a big yes.
Holding the engine from turning is problematic w/o the proper tool and when the torque required to loosen is also enough to tip over the engine on a stand.
Since a lot is removed you have room for a strong breaker bar resting on the frame rail. The starter is your friend
Impact
---- Processing Individual ----
Z1XX Upholstery
Seats front and back in Epingle / leather englishgruen,
As Schl.Nr. B9EG.
Front seat backrest in Montana Englishgruen (No. 8 174 861)
Other interior equipment as for Volleder Nappa englischgruen,
Schl.Nr. P5EG
If you have a REALLY nice impact and air compressor to run it, out of the car should be fine. Me personally, I would do it in the car.
In car,long pipe/jack handle & soak it with Kroil or something. Nice slippers.
2001 | DINAN 7 Sport | S62 Swapped 6-Speed
DINAN Springs & Exhaust | 750 Brakes | M-Pars | Monsoons | NBT Nav/Radio
Dual Pane Glass | Black & Sand Int.
2001 | 750iL | AlpineWeiss III
@scotthduke on Instagram
This method never fails.
Pipe from Home Depot, 5 ft steel, I think 2 inch inner diameter
Yup, I suggest in car as well.
