Results 1 to 12 of 12
Thread: Would you loosen the Jesus bolt before pulling the engine?
    Jul 2013
    Chicago
    2001 740iL Silver/Grey
    Or would it be no different on a stand? Seems like maybe I should get it started before it’s out of the car. At this point everything is detached except the driveshaft and maybe a connection or two I haven’t found yet. Top side is ready to go.
    Dec 2016
    Springfield, VA
    2001 750iL DD74441
    Depends on your stand and mounting. If “loose” then no; it “tight” then okay.
    Advantage of in place: vehicle mass is counterbalance.
    Advantage of out: don’t have to worry about something damaging the body if it slips.
    2001 750iL DD74441
    Stock
    RIP: 2003 540iA Sport GS56111
    H&R front springs, Ultimate Cup Holder, Euro Dash & Armrest, Grom, BavSound Stage1
    Jul 2013
    Chicago
    Quote Originally Posted by TheAngryBear View Post
    2001 750iL DD74441
    Stock
    I’d say before then.....haha
    Dec 2016
    Springfield, VA
    2001 750iL DD74441
    Quote Originally Posted by armiller1 View Post
    Well, you might not have enough access there... lol
    2001 750iL DD74441
    Stock
    Nov 2011
    Greedland
    99 540i6, 02 X5, Tundra
    I like my method,
    E85 fueled, Eaton m112 supercharged 4.5L M62TU, TTV racing flywheel, Spec stage 2+ clutch, 88c thermostat, eibach sway bars, wavetrac 3.15 lsd, m5 steering box, Quantum 340lph fuel pump, Dinan camber plates, some powerflex bushings, Supersprint headers, M5 cats, 2001 gas pedal upgrade and many other things done. all diy by me
    NW suburban Chicago
    hiss by my window
    Yes, absolutely if you intend to dismantle the engine. If you have a super duper impact then no but for those of us relegated to hand tools, a big yes.
    Holding the engine from turning is problematic w/o the proper tool and when the torque required to loosen is also enough to tip over the engine on a stand.
    Since a lot is removed you have room for a strong breaker bar resting on the frame rail. The starter is your friend
    Jul 2013
    Chicago
    Quote Originally Posted by 1999 540i m View Post
    I like my method,
    Haha! Nice slippers!
    Feb 2013
    The Motor City
    1997 750 IL
    Impact
    ---- Processing Individual ----
    Z1XX Upholstery
    Seats front and back in Epingle / leather englishgruen,
    As Schl.Nr. B9EG.
    Front seat backrest in Montana Englishgruen (No. 8 174 861)
    Other interior equipment as for Volleder Nappa englischgruen,
    Schl.Nr. P5EG
    May 2014
    kitsap, wa
    1995 740IL
    If you have a REALLY nice impact and air compressor to run it, out of the car should be fine. Me personally, I would do it in the car.
    Mar 2011
    Greenville, NC
    2001 7-S62, 2002 X5 S2,
    In car,long pipe/jack handle & soak it with Kroil or something. Nice slippers.
    2001 | DINAN 7 Sport | S62 Swapped 6-Speed
    DINAN Springs & Exhaust | 750 Brakes | M-Pars | Monsoons | NBT Nav/Radio
    Dual Pane Glass | Black & Sand Int.
    2001
    | 750iL | AlpineWeiss III
    @scotthduke on Instagram
    Dec 2011
    Lancaster CA
    e34,e38,e39,e46,e70,e90
    This method never fails.
    Pipe from Home Depot, 5 ft steel, I think 2 inch inner diameter
    VA
    E63AMG/Z31/Tacoma/F31
    Yup, I suggest in car as well.
  1. Replies: 5
    Last Post: 11-03-2013, 01:16 AM
  2. Replies: 9
    Last Post: 06-20-2005, 03:40 PM
  3. Anyone stripped the top tranny bolt before?
    By Austin in forum 1991 - 1999 (E36)
    Last Post: 10-25-2004, 06:14 PM
  4. Replies: 18
    Last Post: 10-22-2004, 05:04 PM
  5. Self loosening OE lug bolts & wheels
    By M3 Lee in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 09-22-2003, 10:20 PM
