Results 1 to 5 of 5
Thread: e30 320 stock muffler hangs low
    Aug 2018
    norway
    1986 320, 1991 190E
    hello
    To get my 86 320i ready for inspection I needed a new exhaust. I bought bmw parts and have installed it. However, the rear muffler hangs to low so I cant mount it on metal hangers.
    First I tried hanging it up, then attached the mid muffler to the two front pipes, but that didnt work. Then I bolted together the front pipes to the mid muffler, but now the rear hangs too low.
    Should I just jack up the muffler until I can bolt together the hangers or can that break anything? Whole exhaust is now only mounted to the car by the manifolds.
    323i E30's Avatar
    323i E30 is offline ⅂!ʈө !ƨ l!ʞө ɐ ʇөlөbµouө
    Jan 2013
    Europe
    M52 E30 touring & E91
    So what's preventing it from reaching the metal hangers? If that's just gravity, I'd say lift it and put it in the hangers
    There's also this bracket somewhere halfway the exhaust near the muffler that should slide in a rubber underneath the car.
    Best get some fresh new hangers while you're in there btw (if you didn't already do so).
    ^ true story
    D̶i̶b̶s̶ ̶o̶n̶ ̶t̶h̶e̶ ̶E̶2̶1̶
    Aug 2018
    norway
    1986 320, 1991 190E
    Quote Originally Posted by 323i E30 View Post
    Thanks, I'll give it another shot tomorrow. I'll try to loosen the bolts in the middle, maybe that helps, then tightening it up after. When I tried hanging up the exhaust in the rear and then mounting it in the middle, it just hit heatshields and I couldnt get it high enough for the front pipes. The rubber and metal hangers are new, but aftermarket I think. They seem almost too small for the big rear muffler.
    323i E30's Avatar
    Jan 2013
    Europe
    You could put the new exhaust next to the one you removed to see if anything's different regarding angles or mounting positions.
    I assume they are similar though, so it should fit.
    Maybe you need to push the exhaust a bit sideways to get it in the right position. It shouldn't have any obstruction there.
    Have you test-fit the hangers with the muffler, since they appear to be too small?
    I don't know if the mufflers and hangers come in different sizes, because of either single- or dual pipe exhaust systems
    ^ true story
    Aug 2018
    norway
    1986 320, 1991 190E
    the old exhaust is the most homemade collection of pipes ive ever seen, haha. A million welds and bends. The new one should fit, its original bmw parts.
    The hangers will fit if I twist and turn the muffler upwards, but that seems to be impossible when its connected with the front pipes.
    I'll try again tomorrow, kinda hard when Im doing it myself + a jack that lifts the car 10 inches off the ground.
  1. E30 325is Stock muffler for sale 1yr old $150
    By Wheels5550 in forum Engines, Performance Parts & Software
    Last Post: 12-23-2008, 07:36 PM
  2. WTB: E30 Stock Muffler / WTT Brullen DTM Tips - SO CAL
    By timers-88-325i in forum BMW Parts Wanted
    Last Post: 12-23-2008, 07:34 PM
  3. Muffler Hanging LOW
    By dongmooner in forum 1992 - 1999 M3 (E36)
    Last Post: 09-09-2008, 02:07 AM
  4. Is the stock Cat supposed to hang low?
    By runetang[1337] in forum 1991 - 1999 (E36)
    Last Post: 05-04-2007, 10:50 PM
  5. FS: E30 M3 stock muffler 30k mile car
    By dfwidner in forum BMW Parts For Sale
    Last Post: 06-30-2004, 11:09 PM
