Results 1 to 4 of 4
Thread: Window issues
    May 2012
    New Albany, Indiana
    2001 BMW 330ci
    Window issues
    I have and 01 330ci. On the way to work yesterday my passenger window started giving me problems. I heard a bit of a grinding noice while lowering the window. When I tried to put it back up it stopped about 6" short. It would go down but wouldn't go back up past that initial stopping point. Any input is appreciated. Does it sound like the regulator? I've taken the door panel off and dont see anything obviously broken.
    Jan 2016
    Ca
    2001 525it
    The window regulator sounds like it is coming apart look closer
    May 2012
    New Albany, Indiana
    2001 BMW 330ci
    So I removed and installed a new window regulator in my passenger door. Everything has gone pretty smoothly, but I do have a question about installing the glass. The new regulator has a zip tie thru the rear clip that holds the window. Does it need to be removed? Every write up and YouTube video has been pretty vague about how to go about installing the glass. When I took the glass out the clip came apart in several pieces and fell down inside the door, so I'm not really sure how it should look. Any help?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Go to E46Fanatics and find the video showing you how to replace the regulator. It’ll answer all of your questions.
  1. window issue, nothing found when searched
    By mtecnic in forum 1991 - 1999 (E36)
    Last Post: 01-07-2005, 06:48 PM
  2. Power Window Issue.
    By ghettozn in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-01-2004, 08:40 PM
  3. VERT: rear window issues
    By David.Dunbar in forum 1991 - 1999 (E36)
    Last Post: 08-05-2004, 04:36 PM
  4. Window issue...
    By PortalBMW in forum 1992 - 1999 M3 (E36)
    Last Post: 04-19-2003, 11:20 PM
  5. 95 325is WINDOWS ISSUES HELP!
    By cleoent in forum 1991 - 1999 (E36)
    Last Post: 10-11-2001, 06:46 PM
