Results 1 to 6 of 6
Thread: DIS data transmission disrupted; port error; driver error
    Aug 2014
    kentucky
    '98 Z3 M Roadster
    Hey guys I'm kinda stuck in the water instill I can get my DIS working properly. I need to align a DME with the EWS. Basically I have a laptop I only use for my BMW software. I tried playing around with another program and windows updated the computer software. DIS use to work perfectly. I was only able to roll it back to January. I have tried to update drivers, and all that. So my problem that I think are causing the problem 1) my communications port is showing an error, but the USB serial port shows fine. 2) inside of DIS you have the little yellow scanner icon mine is not showing it is active or connected; the connection with the DME is good. I have connected this before in the past but I have no idea how I did that. I'm pretty sure if I can connect editables It will all work. Any help would be awesome and really appreciated.
    Update: I have no diagnostic head. How do I re-connect?
    Built S52 w/Dinan ISR-3 kit, NickG Stage 2+ Tune, Dinan Vortech V2 Supercharger, Dinan Air to Air Intercooler, Dinan CAI, Porsche 803 HFM, Buldogge 6" crank pulley, Griptec 2.90" blower pulley, Eurosport UD pulleys, Dinan 3.38 Diff, Dinan front/rear Swaybars, Dinan springs, Koni Yellow Sport Struts, Ground Control end links, South Bend Clutch Stage 3 Organic, AASCO Light Weight Flywheel 18.5#, Zionsville Radiator & Oil Cooler, Riot Racing BBTB, Schrick Intake Manifold, 42# Injectors, Schrick cams 264/256, Forged Wiseco pistons 9.0 comp., Forged Eagle rods, Supertech dual valve springs & valves, VAC crank & bearings, Supersprint mufflers, Euro Z3 midpipe, Raceland euro headers, Walbro 255, Bevauto ignition coils, Vortech Mondo bypass, Bailey Diverter DV30, Ireland Rear Subframe Bushings, Mason Engineering Strut Brace, Mason Engineering Clutch Petal, Apex 18" EC-7 Wheels, Full Custom Sound System, two trunk lids (with & without OE spoiler), Hardtop, Trunk full of AK's...
    Jul 2004
    Houston, TX
    36 Cylinders
    While this won't help your DIS.. you can use this small app to sync your DME really quickly.
    https://www.bimmerforums.com/forum/s...0-vagcom-cable
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Aug 2014
    kentucky
    '98 Z3 M Roadster
    I was able to connect the diagnostic head, but now I have "data transmission disrupted"...
    Jul 2004
    Houston, TX
    36 Cylinders
    What are you using as a diagnostic interface between the laptop and the car?
    -Abel
    Aug 2014
    kentucky
    '98 Z3 M Roadster
    k+dcan (for DIS) and just tried vagcom (Vag KKL) cable with the EWS standalone app; both connected to a 16/20 pin adapter. Nothing is recognized, so I bought a driver install app online. I'll update you tomorrow.
    Aug 2014
    kentucky
    '98 Z3 M Roadster
    I finally got DIS to work! Wow, that was a crazy day! -- It was several small things I suppose. Much harder this time than the first time I used DIS.
  1. EGS Transmission failsafe mode and INPA error
    By sklingler93 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-15-2018, 09:36 AM
  2. DIS Data transmission disturbed with engine running
    By whiskychaser in forum Diagnostic Software
    Last Post: 11-07-2013, 06:30 PM
  3. Driver error last night, is my car ok?
    By topspin in forum 1991 - 1999 (E36)
    Last Post: 06-12-2007, 11:19 PM
