I need some information regarding this before I make an attempt and fail at it, my buddies e36 comes with a Manual transmission but he wants to do an automatic swap, the deal is I get to take the manual tranny... but I’m unsure about the wiring, will the Manual engine harness work with an Automatic transmission? If not will I be able to use a harness that came from another OBD2 engine of the same model? Any information helps thanks!
You will need to swap wiring harness, part of the driveshaft, and also source a computer for the auto trans
Do you know if there is a specific automatic transmission ecu I’m supposed to use? Thx!
I don't know how big of deal it is, but the main DME also has slightly different software for the automatic. You can flash the DME with an automatic trans version. You would need some $25 software and a cable that doesn't cost to much and a ROM file.
https://sites.google.com/site/openms...s41-flash-tool
Also, when you have the automatic (hopefully its good), it is wise the have the torque converter rebuild, it's about $125 (rockauto.com), replace the o-ring on the input shaft and replace the input shaft seal.
Reverse of this:
http://e36-tech.com/DIY/5speedswap.htm
Use the auto trans computer thats with the auto harness (im assuming youre getting used parts from a salvage yard?)
Since you say the car is obd2, once you change from 5-sp harness to auto, you may have a problem with EWS but im not 100% sure about it (my EWS is deleted by switching to obd1). Let us know how it goes...you only have 2 posts asking questions with no contribution to this forums so im not sure how many ppl are willing to respond. The search button is your friend. Good luck
Rich
Current lineup: 99 BMW M3vert (project) , 05 Mazda RX-8, 04 Mercedes CLK320, 03 Chevy Express 1500 (work van).
Previous rides: 07 Mazda RX-8, 92 BMW 325iNV, 94 BMW 325iC, 94 BMW 325i S50 M3 clone, 84 Mitsubishi Cordia Turbo, 84 Mazda B2000 lowrider, 88 Toyota Tercel, 88 Honda Accord, 93 BMW 318i, 95 Nissan Altima, 89 Toyota Camry, 95 Mitsubishi Eclipse GS-T, 93 BMW 318is, 84 Toyota Tercel, 96 Mitsubishi Eclipse GS-T, 97 BMW 528i 1JZ swap, 94 Acura Integra 4dr, 88 Toyota Corolla Wagon, 97 VW Jetta GLS, 86 Toyota Corolla AE86 4A-GZE supercharged engine swap, 94 Lexus LS400, 95 Isuzu NPR Turbo, 01 Suzuki TL1000R, 98 Honda CBR600F3, 99 Yamaha R6 and countless other dirt bikes and toys
