Results 1 to 7 of 7
Thread: M62tu code 33.. TCG?
    Feb 2012
    Gesneso, Illinois
    2001 BMW 540i 6 speed
    Well I treated the ol 540 with some wheels.. I got some 18" Beyern mesh staggered wheels and got them on. Next day cel comes on. Code 33 Vanos inlet camshaft control bank 1. I can hear some chain slap... I took a video scope and looked in the oil fill hole towards the center and it looks like the guide is gone. this could throw the code? Bad cam position sensor? Vanos solenoid? I'm sure it been gone over but what's the best way to verify the guides are bad? Since I heard the chain slap I haven't really driven it and don't plan to until the problem is verified and addressed.
    01 540i/6 06/01 - Joy ride
    95 GMC Yukon - Daily
    00 BMW K1200RS - Cruiser
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Drop the oil pan and see what's in there besides oil.
    How many miles on the car?
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Quote Originally Posted by MY1E38 View Post
    Since its a 'control limit' error, its unlikely the cam sensor. The solenoids possibly could cause inability to hit control target but those really have (luckily cuz they $$$) a super low failure rate. Sounds like you are visually and audibly confirming some guide loss... so... Like Jim says drop the pan and look for the debris.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    San Jose, CA
    1997 BMW 540i 6 speed
    If you have circa 150k miles on it, likely bad guides. If mileage is considerably lower, try replacing the chain tensioner.
    Feb 2012
    Gesneso, Illinois
    ive replaced the tensioner. and its only got about 130k miles. gonna drop the pan here soon.
    Feb 2012
    Gesneso, Illinois
    been awhile. forgot about the thread. it was infact the TCGs. ordered from fcpeuro and took roughly 8 hours and shes back on the road. also ordered the timing tools on ebay.... they are surprisingly decent tools! everything worked out fine. upper timing covers had to come back off due to oil leaking where the block, upper timing cover, and valve covers meet. still seeps a little but i can live with it!
    Jun 2019
    US
    e39 540i
    Did you reseat all the studs on the cam caps? The studs should be protruding more then 17.5mm from the top of the caps.
  1. Error Code 33 on M62TU - Fix
    By AquilaBMW in forum 1995 - 2001 (E38)
    Last Post: 09-10-2022, 11:37 AM
  2. 530i ID Code 33 - Engine Problem
    By DAMNdru in forum 1996 - 2003 (E39)
    Last Post: 05-02-2011, 12:49 PM
  3. 99 540i help codes 33 and 34
    By Reaper13 in forum 1996 - 2003 (E39)
    Last Post: 04-05-2010, 03:39 AM
  4. evap system shutoff valve CE code 33
    By Ron97M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-23-2009, 07:32 PM
  5. ABS Fault Code 33 .. HELP
    By M3corey in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-05-2003, 06:31 PM
