Results 1 to 22 of 22
Thread: How to bypass auxilary water pump?
    Sep 2018
    Fort Lauderdale, FL
    1998 540i
    my car is a 1998 540i manual. The aux water pump is leaking and i want to know how i can temporarily bypass it? i should have my new pump in a few weeks but until then i need to drive this car to go to work. I notice there is a hose coming from the back of the passenger side head and going to the pump then there are 2 hoses at the top of the pump going somewhere else, but which hoses do i connect together??
    Sep 2018
    Fort Lauderdale, FL
    1998 540i
    my car is a 1998 540i manual. The aux water pump is leaking and i want to know how i can temporarily bypass it? i should have my new pump in a few weeks but until then i need to drive this car to go to work. I notice there is a hose coming from the back of the passenger side head and going to the pump then there are 2 hoses at the top of the pump going somewhere else, but which hoses do i connect together?? https://www.realoem.com/bmw/enUS/sho...diagId=64_0994
    Sep 2018
    Fort Lauderdale, FL
    1998 540i
    can someone please point out which hoses to connect to bypass the aux water pump , and also which hoses would bypass the heater core? thank you very much i really do appreciate the help.
    May 2014
    Hockinson Washington
    Two 2003 540i6 Msports
    If you take the valve and pump assembly out of the loop (car) and simply connect the hoses together, you're gonna have full heat and you won't be able to modulate it very much. You are gonna get "toasty". If you simply "cap and stow" the hoses, you won't have any heat.
    How bad is it leaking? Is it just seeping with an occasional drip, or is it a trickle?
    Just wondering if you could let it be for now.
    Btw, when you disconnect the hoses to replace it, hardly any coolant will come out. When I replaced mine a few weeks ago, I didn't even have to add coolant when I was done.
    I do not believe in a risk free society where the thrill of living is traded for the safety of existence. Nick Ienatsch
    The law does NOT determine "right" from "wrong". They are unrelated.
    If you put cheap parts on your car, you will soon have a cheap parts car.
    JimLev's Avatar
    JimLev is online now Artifically Aspirated Moderator
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Post at 10:12, 10:13, 10:23 looking for an instant answer? Chill.
    Hook hose 5 to hose 12.
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Why would it ever take a few weeks to get a new pump? Financial reasons? I'd just whack a new one in there right away, or, try to find a cheap junkyard one as a stopgap, or, worst case... as mentioned keep driving and adding coolant if the leak is minor.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Sep 2018
    Fort Lauderdale, FL
    1998 540i
    thank you , so looks like connecting 5 to 12 would bypass the pump yes, but how could i still have heat? i was thinking if i connected 5 to 9 and then 8 to 12 i would still have heat but bypass the pump?
    yes, financial reasons at the moment and its leaking pretty bad. which hoses would you connect together to simply bypass just the pump?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    you still will get heat when the heater is on. The aux water pump just works independent from the main water pump, as it is electric driven and pumps per hour abt. 900 ltr into the heater core, no matter what the RPM of the engine is.
    May 2014
    Quote Originally Posted by shogun View Post
    I believe the hot water goes from the aux pump, through to the heat control valves. If the aux pump is "capped off", how is hot water gonna get to the heat control valves and eventually the heater core? If the lines are connected together (bypassing the aux pump and heat control valve assembly) it seems like he's gonna get an uncontrollable (or at least barely controllable) heat condition in the cabin.
    Jan 2005
    Japan
    yes, but he want to have a cheap solution, and if he connects hose 5 to hose 8 or 9, only 1 side gets heat
    08 Hose f water valve and right radiator 1 64218391017 (feed)
    09 Hose f water valve and left radiator 1 64218367929 (feed)
    In case he connects hose 5 with 12, the heater core is by-passed, no heat at all.
    If he wants to heave heat on both sides, he has to use a y-tube and connect 5 to 8 and 9. To control the heat the cheap way, a water shut off valve from the plumper will do.
    On the E32, E31, E34 it is easier, there aux water pump has an inlet hose and a outlet hose, the outlet hose goes to the heater valves, so when by-passing the aux water pump on these cars, both sides get heat, as it goes into feed line heater valves, but on E39 not possible, see drawing
    Dec 2004
    CT, USA
    e28, e34, e39
    How much are you guys buying these for? I see an oem valve is like $450? And do you actually need the aux pump? You can buy a valve without the built in aux pump for around $80.
    demet
    Mar 2010
    somebody once said:
    2003 M3CicM6 TiAg
    Former:
    Oregon
    '99 528i/5, '01 Boobaru
    davidre391, is it actually the pump that's leaking, or a hose that's connected to the pump?
    Nov 2011
    Greedland
    99 540i6, 02 X5, Tundra
    Quote Originally Posted by demetk View Post
    I used the control valve from a X5, no pump works great
    E85 fueled, Eaton m112 supercharged 4.5L M62TU, TTV racing flywheel, Spec stage 2+ clutch, 88c thermostat, eibach sway bars, wavetrac 3.15 lsd, m5 steering box, Quantum 340lph fuel pump, Dinan camber plates, some powerflex bushings, Supersprint headers, M5 cats, 2001 gas pedal upgrade and many other things done. all diy by me
    Dec 2004
    CT, USA
    e28, e34, e39
    Quote Originally Posted by 1999 540i m View Post
    Thanks. It's good to know I can use the one without the pump.
    demet
    Philadelphia, PA
    2005 M3 & 2004 330i
    Quote Originally Posted by Santaclaus4 View Post
    As long as he retains a valve, the heat will work and be controllable. The main thing that would be lost is the parked car ventilation which relies on the aux pump.
    On some models that run lower coolant temperatures (most of BMW's diesels and M models), the aux pump also plays a role in getting heat to work more effectively (as evidenced by E46 diesels and M3s having an aux pump despite not having any parked car ventilation option).
    JimLev's Avatar
    Sundance Mesa, NM
    Without the pump he could have some issues purging the air out of the cabin heater box if he ever drained the system.
    Sep 2018
    Fort Lauderdale, FL
    1998 540i
    Quote Originally Posted by TerraPhantm View Post
    im gonna try to bypass it later today temporarily by getting a T shaped valve at the hardware store. Does anyone know what size those hoses are? or approx size so i know what kind of valve to buy. The Lowes store near me has a prestone T valve that i could prob use.
    Jan 2005
    Japan
    you have to measure the diameter of the hoses, realoem does not mention hose dia., just the size of the hose clamps
    06 Hose clamp L16-30 64218367179
    07 Hose clamp L28-33 07129952113
    10 Hose clamp L18-24 07129952109
    11 Hose clamp L16-30 64218367179
    13 Hose clamp L16-30 64218367179
    This is the heater valve and aux pump for E34, E32, E31, there the aux pump is separately mounted and has an inlet and outlet which goes into the water valve feed, so much easier to by-pass http://bmwe32.masscom.net/johan/wate...e_and_pump.jpg
    http://bmwe32.masscom.net/johan/wate..._and_pump2.jpg
    May 2014
    Yes, they really are that expensive. I just replaced mine a few weeks ago. After looking online I finally came to the conclusion it's just gonna be a spendy part and that's that. Now I probably ​won't have to worry about it for another 15 years.
    Dec 2004
    CT, USA
    e28, e34, e39
    Wouldn't it be nice if the parts of now are build to last as long as the parts of then? We should make a point of revisiting this thread in 15 years for an update.
    demet
    JimLev's Avatar
    Sundance Mesa, NM
    I saw a few of them in the junk yard 3-4 months ago, was thinking about getting them but didn't.
  1. bypassing aux water pump
    By felnik in forum 1988 - 1996 (E34)
    Last Post: 01-23-2013, 03:54 PM
  2. Auxilary Water Pump
    By jgatto72103 in forum 1988 - 1994 (E32)
    Last Post: 12-23-2011, 02:03 AM
  3. E39 Auxilary water pump 540i
    By TD or Not TD in forum Engines, Performance Parts & Software
    Last Post: 07-17-2011, 09:59 PM
  4. New auxilary water pump
    By DAS KOMMISAR12 in forum 1995 - 2001 (E38)
    Last Post: 12-27-2010, 03:36 PM
  5. Is there auxilary water pump on E39 525i?
    By CWY M5 in forum 1996 - 2003 (E39)
    Last Post: 09-15-2006, 02:44 PM
