Results 1 to 5 of 5
Thread: 2nd parasitic draw post 98 740i pre 6/98
    West Nyack, New York
    86 635csi 98 740i 96 MB
    So I checked out mA as suggested but was frustrated with .002 readings on all
    fuse circuits. So before I narrowed what I was not doing correctly and having to amp clamp,
    I read volts from the battery to try and isolate the ign switch.
    Battery full charge, 13.09 volts, battery cables not connected.
    3 days latter 12.89 volts.
    Connected battery cables and disconnected ign switch harness.
    Next day AM 12.2 volts
    2 days latter AM 11.86 volts
    Same day PM 11.67 volts
    Connected ign switch harness
    Next morning 11.31 volts
    2 days latter 8.16 volts
    Now charging battery.
    guess a new switch is to be ordered.
    Any help on confirming and direction before doing an amp test on all those God Damn circuits will be appreciated.
    Bob V
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    The results are consistent with either battery drain - or - just a battery that has reached the end of its life. At a terminal voltage of around 8 Volts the battery is being permanently damaged very quickly - if it's been at 8V for any length of time it is dead as a dodo.
    Batteries are notoriously difficult to measure to ascertain if they can hold a charge - and with those readings I think I would start with a new, fully charged battery as a starting point, you cannot measure battery drain with a bad battery. I would then do an actual closed-current battery drain test:
    https://www.meeknet.co.uk/E38/E38_Battery_Drain.htm
    You can used a DC current clamp on the negative lead - the latest ones work pretty well as long as they are pre-calibrated (zero the meter when the clamp is next to, but not around the negative lead).
    My BMW Repair YouTube Channel
    Timm,
    Brand new AGM battery. Was fully charged @ 13.09 volts
    This is the amp clamp ( https://pdimeters.com/docs/pdf/manuals/CA-60.pdf )
    I'll use an inline fuse holder with spade connectors to check mA on all circuits
    and I'll follow your sleep instructions. I hope I find high mA on a circuit to fix this PITA.
    Thanks Timm
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    No need to remove fuses - and you mustn't remove them as this resets the 16-minute timer and removes evidence. Instead, use this method:
    http://www.meeknet.co.uk/E64/Fuse%20...20Readings.pdf
    What actually is the current demand after 16 minutes?
    OK thanks for the heads up
  1. FS: Water pump for pre 98 740i(L) $120 shipped
    By Alpine6And7 in forum 1995 - 2001 (E38)
    Last Post: 03-01-2009, 02:16 AM
  2. 1st - 2nd gear shift problem '98 740i
    By mudn4x4 in forum 1995 - 2001 (E38)
    Last Post: 03-22-2004, 08:06 PM
  3. New member - '98 740i & '03 325Ci
    By ggoodlife in forum Off-Topic
    Last Post: 04-17-2003, 10:15 PM
  4. FS: 98 740i
    By umnitza in forum BMW Cars For Sale / Wanted
    Last Post: 07-03-2002, 02:50 PM
  5. 98 740i Wheels & Tires OEM
    By umnitza in forum BMW Parts For Sale
    Last Post: 04-24-2001, 08:38 PM
