Results 1 to 8 of 8
Thread: Mechanical tensioner with idler pulley confusion
    Jan 2018
    Oregon
    1988 e30 325
    So my 1999 e39 528i wagon had a hydraulic pulley and when it started to make noise i bought a new one not realizing that i had bought the mechanical one. Thankfully it fits fine on the car but I heard somewhere that cars that came with a mechanical tensioner didn't have idler pulleys. Any of you guys know if i should keep the idler pulley on?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    moved to E39 forum
    San Jose, CA
    1997 BMW 540i 6 speed
    Where did you hear that? How else can you keep the belts tight?
    Jan 2016
    Ca
    2001 525it
    Who needs the belt
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    So your replacement is just fixed-tension and doesn't have the spring shock? As long as it all fits, it should be OK but the other one is far more desirable for 2 reasons - you get 'perfect' tension (no need to worry about too tight / too loose) and it 'self adjusts' vs. a fixed tensioner. If you bought your tensioner from FCPEuro you could just send it back and get the right one, even if it was used! #yetanotherFCPplug
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Philadelphia, PA
    2005 M3 & 2004 330i
    They both exert tension. One exerts it via a spring, the other via a hydraulic cylinder. Bmw used both on I6s. Pattern seems to be automatics got the spring from the factory while manuals got the hydraulic one, but there are exceptions to both.
    Mar 2010
    Quote Originally Posted by TerraPhantm View Post
    Ahhh I thought he meant he got some kind of fixed-tensioner. Nevermind. Don't change it, should be fine.
    2003 M3CicM6 TiAg
    Former:
    Los Gatos CA
    1987 325is, e34, Z3, e39
    The "hydraulic" tensioner is a regular coil spring in an oil-filled chamber, with a rubber cap. The roller assembly pivots on a pair of grease lubricated needle bearings. At this age, the factory assembly probably has a split rubber cap and gummy or dried-out grease.
    The "mechanical" tensioner is a large torsion spring. The spring is operated dry, with the two half-cylinder castings contacting each other. This sometimes results in an annoying squeaking. The spring is also vulnerable to rusting, especially if you don't have the under-engine "splash cover" installed.
  1. tensioner and idler pulley rub
    By wrayth in forum 1999 - 2006 (E46)
    Last Post: 03-08-2015, 03:00 PM
  2. How to reinstall hydraulic tensioner for idler pulley?
    By apirkle in forum 1992 - 1999 M3 (E36)
    Last Post: 03-05-2011, 03:27 PM
  3. Video demonstration: Tensioner and Idler pulley test
    By pimpin325ci in forum 1999 - 2006 (E46)
    Last Post: 08-21-2010, 12:16 PM
  4. Replacing Belt Tensioner and Idler Pulleys: Quick Sanity Check, Please
    By Llama in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-09-2007, 02:38 PM
  5. Tensioner & idler pulley torque specs?
    By M3C in forum 1992 - 1999 M3 (E36)
    Last Post: 04-21-2004, 05:17 PM
