Results 1 to 18 of 18
Thread: car won't stay on
    PA & MI
    '01 740iL#2,'02 CBR954RR
    car won't stay on
    My car won't stay on after cranking. It will start run, very rough, then immediately shut down. I can't even move it because if i press the gas pedal it will stop, but as I said it won't stay running anyway. i hooked up my laptop and ran INPA and got several errors. i haven't cleared any because i need to find out how serious they are and fix what the problem is.
    So fam, I need help deciphering these. I copied screen shots of those errors in the attached file. What really concerns me is the status DME internal error. I've done nothing to my DME, at least not directly that I'm aware of. What is that about?
    Any suggestions on causes & solutions?
    9-16-18 errors.pdf
    Thanks for any help.
    "A good scientist is a person with original ideas. A good engineer is a person who makes a design that works with as few original ideas as possible. There are no prima donnas in engineering." - Freeman Dyson
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    Maybe I will beat Timm to this: check your DME plug for coolant. Could be that DME is kicking the bucket. We recently had a member that had issues and it ended up being a bad DME.
    https://www.bimmerforums.com/forum/s...0#post30105810
    Current: 2007 Z4 M Coupe (blue/black)
    Previous: 2001 740iL Sport (black/black), 2000 528i Sport (black/tan), 1995 318is (black/black), 1991 318is (white/black)
    IL
    2000 740i sport
    Try disconnecting the maf plug and see if it runs first...
    Sent from my SM-N910T3 using Tapatalk
    PA & MI
    Thanks guys. I will try this tomorrow.. been a loooong day.
    Purp I think i will also clean that MAF too
    IL
    2000 740i sport
    Also check the tstat plug and dme for corrosion from coolant...
    Quote Originally Posted by kahlilj View Post
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    That does sound like a real DME problem - especially as you have a Watchdog error code - a Watchdog fault means that the processor has stalled, and it shouldn't have done that! Possibly there's dampness in there - time to hook it out.....
    My BMW Repair YouTube Channel
    PA & MI
    Quote Originally Posted by purplecty View Post
    Checked the dme for corrosion and signs of coolant debris? It was clean.
    Can someone please tell me how getting coolant in there is possible? I’ve seen reference to that in other posts.
    Anyway I also cleaned my MAF sensor, but in the process of looking over the car again this is what I noticed and I’m sure that it’s the culprit...
    IL
    2000 740i sport
    What did you notice is the culprit?
    PA & MI
    Notice the air gap between my intake hose and TB! I’m 99% certain this is the culprit! Arrrgh! I should have known and suspected this. it’s happened before, but it’s been maybe 2 years since it occurred. Smh
    IL
    2000 740i sport
    Yes i see! yours is supercharged right? Isn't that connection always an issue with that tubing?
    PA & MI
    I’m going to button everything up. Reconnect that air intake and my instrument cluster. I forgot I had removed that bc got one from an x5 that In going to replace it with and didn’t reconnect the original. That might be the cause of the watchdog error. ..??
    PA & MI
    Yep! So a while back I replaced the supplied tubing (rubber hoses) and clamps with better aftermarket parts and the issue subsided. However I should clean the hoses periodically because of the oil that forms inside and eventually seeps through which makes it slip out in some spots. The connection at the TB has always been a weak link in my setup.
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    Let us know if it solved your issue!
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Fortunately, after looking at the error pdf again I notice that the watchdog error is not for the main DME but for the steering angle sensor!
    PA & MI
    Quote Originally Posted by Ruskii View Post
    Will do!
    PA & MI
    How do resolve that aside from replacing the sensor?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Replacement would be the way to go - and be happy it wasn't the DME!
    PA & MI
    True, very happy. But would be very surprised if it was corroded. But what would cause that?
    Good news is problem solved. It was the coupler and air intake hosing. I disassembled everything, cleaned up the oily and debris as well as my MAF sensor and she fired right up.
    Now I have the brake, ABS & reaction lights on
    But thanks all for replying with ideas & things to check into. I’ll do some searching and figure out what’s wrong there.
  1. Please help... Car Won't Stay Running!!!
    By apocalypse01 in forum 1991 - 1999 (E36)
    Last Post: 07-23-2009, 02:03 AM
  2. Car won't stay in gear-clutch pedal won't disengage(come back up)
    By Shark Attack in forum 1976 - 1989 (E24)
    Last Post: 04-19-2009, 06:23 PM
  3. Replies: 8
    Last Post: 06-14-2008, 12:41 PM
  4. Car won't stay running after new alternator
    By ixe30 in forum 1983 - 1991 (E30)
    Last Post: 11-04-2006, 06:07 AM
  5. Car won't stay running, any ideas?
    By bossmankx in forum 1975 - 1983 (E21)
    Last Post: 10-03-2006, 04:41 PM
