Results 1 to 15 of 15
Thread: diagnostics
    Oct 2012
    Penna
    2000 z3
    diagnostics
    I have down loaded the INPA software and associated software. I have ordered and received the USB to OBD2 connector hardware. I have not connected anything to the vehicle as I am afraid I will (brick) it and turn it into a lawn ornament. Has anyone else felt this way and should I just go for it. I have no CELs and the car runs excellent. I was just curious and really would like to wander around the cars brain. What to do??
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    You'll be fine. I haven't bricked mine yet Knockwood. The worst you could do is clear adaptations but that's no biggie it'll relearn. You would have to put the Ecu in read/write mode with jumpers before you'd need to worry
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    Of course I was afraid to hook it to my car. It took me 2 full trys to get in on the laptop..... Sometimes life is a matter of courage. ....
    Oct 2012
    Penna
    2000 z3
    Gees, it took me about a week of checking and trying to be sure of what I was really downloading. I guess I was really skeptical. I seriously think I will connect it all up tomorrow and see what happens. Still a little chicken though. I'll post the progress and findings.
    Oct 2012
    Penna
    2000 z3
    Set everything up today. Plugged everything in and turned it on. NOTHING at all. It does not read anything. Back to the drawing board as they say.
    Aug 2012
    Kansas
    Check your comm port settings
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    Yes, it has to be exactly right. Follow EVERY step of instructions EXACTLY (I assume you're using these instructions: http://www.bimmerforums.com/forum/sh...xperimentation . I never really knew what I did wrong the first time. I just started over from beginning, and it worked.
    Oct 2013
    Augusta, GA
    1999 Z3 M-Roadster, 2007
    My experience exactly. It’s almost as if you have to take a run at it once to soften the resistance.
    Sep 2018
    Houston, TX, USA
    1999 BMW Z3 Coupe 2.8
    Hi chuter, dumb question, or should i say pardon my ignorance. Why not use a BMW obd reader or the like? Why go through the trouble of INPA software setup?
    Feb 2012
    UK
    1998 Z3 1.9 5 speed
    Quote Originally Posted by solimans View Post
    Because INPA gives much more information and reads more modules that an ODB reader.
    Oct 2012
    Penna
    2000 z3
    As I have stated I have been trying to get this up and running with no success. I have tried to go back and download again but system states I can't download it again for some reason. I am totally frustrated with this as to me the instructions seem to be misleading and contradictive. I have a good scanner and will use that if I have any problems in the near future. It is not that important as I really only wanted to just see if I could make it work. I can't and to hell with it. I will check again sometime in the future and maybe by then someone will have a program that is way less complicated. Thanks alot guys. P.S. I'll just drive the crap out of it..
    Sep 2018
    Houston, TX, USA
    Quote Originally Posted by BladeRunner919 View Post
    Thanks, i see. Good reason.
    Feb 2004
    san diego
    ...it depands
    Quote Originally Posted by z3forlife View Post
    I also recommend trying this as well as z3forlife mentioned if you haven't already...
    It's been a while since I installed mine so I vaguely remember details, but I do recall fiddling to enable usb comm port to get the cable working (unless you have serial port version).
    2000 Z3 M Titanium Silver / Imola Red+Black Nappa
    2011 328i E92 Space Gray Metallic / Leder Dakota+Oyster
    Since 1987 12 euros / 2 kdms / 2 jdms
    - Zach
    Aug 2012
    Kansas
    If you PM user 328power04 I'm sure he will help you with setup.
    Oct 2012
    Penna
    2000 z3
    I'm done, I do not want to spend any more time on it. Some may get it to work but as of now I can't and I know when to say enough is enough. Thanks to all for trying to help, believe me I appreciate it. Chuter
  1. Diagnostic codes 69 & 70???
    By Jerome in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-06-2002, 11:57 PM
  2. Diagnostic codes 69 & 70???
    By Jerome in forum 1992 - 1999 M3 (E36)
    Last Post: 11-06-2002, 03:28 PM
  3. Replies: 18
    Last Post: 09-13-2002, 08:49 PM
  4. Diagnostic Tool?
    By VelvetFoot in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-24-2002, 06:43 PM
  5. Diagnostic trouble code help
    By UD///M in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-23-2002, 02:54 PM
