I have an 02' 330 ci that has an annoying squeal when the brakes are applied. The squeal seems to be coming from the area behind the pedal. I am assuming it is a vacuum leak/brake booster issue. Any insight on what it is and how it can be fixed.
Can you use your phone or video camera and post a video of the noise?
I am unsure how to attach a video of it.
Upload it to YouTube and then post the link here on this site.
Sounds like the noise could be the brake booster with a vacuum leak.
To verify you could smoke check it thru the brake booster check valve hole
Is it a high pitch squeal? If so then its a brake booster vacuum leak.
