RM European Auto Parts
Results 1 to 7 of 7
Thread: Changing coolant reservoir
    Feb 2008
    Mt. Pleasant, SC, USA
    1997 E36 M3/4/5
    I need to change the reservoir on my E36. Do I need to drain the radiator? Or, do I just drain the reservoir and work fast?
    Thanks,
    Marc
    Marc Plante
    E36 M3/4/5 193k
    Konis+ Dinan Springs, Understeer SS, Shepott European steering Wheel, ZKW Ellipsoids, ECIS Intake+ ATE Foam filter, Stromung Exhaust, Recaro SRDs. JVC Arsenal Head Unit. Alpine MRV-F300 Amp, ADS 535i components, JL Audio Stealthbox Subs
    My Track Rig:
    i7700 / 2080 PC with Assetto Corsa and Content Manager, Samsung Odyssey+ VR goggles
    Fanatec CSP wheel and pedals, SSH Shifter, recaro seat. Home built cockpit
    Mt Pleasant, SC, USA
    Mar 2003
    St. Joseph, Mo.
    95 m3+, 03 ZHP, Mk4 Tdi
    last time i've done this i just worked quickly.
    Aug 2013
    1999 BMW M3 Coupe
    The less messy way is to drain the radiator, yes. You're gonna have to add coolant and bleed it after regardless, so it's just a matter of needing more fresh coolant if you drain the radiator. Everything else is the same.
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    I'd drain the radiator into a big drain pan, then drain the expansion tank as possible. Personally, I can't imagine how you're not going to dump pretty much all the coolant., except what might be held captive in the block. The E36 reservoir is pretty troublesome, to me, but maybe others know tricks which I don't....
    Chris Powell
    BMWCCA 274412
    Mar 2003
    St. Joseph, Mo.
    it's been a while since i've done this on my e36, but, i know the time i did it i did not drain the radiator. well, now that i think about it - maybe that was changing out the level sensor.....hmmm....
    Aug 2013
    1999 BMW M3 Coupe
    Draining the radiator is easy. Draining the engine block thankfully isn't really necessary for this unless you're doing the water pump or thermostat at the same time. The plug for the block typically requires the removal of one of the pre-cat O2 sensors in order to get at it, and then splashes all over the pipes.
    Feb 2008
    1997 E36 M3/4/5
    K. I'll suck it up and drain the radiator. I figure rushing with fluid running out of the bottom line will likely lead to some awkward amateur oversight.
    History is that I THOUGHT I had a bad sensor seal so I changed the sensor. very easy to drain the reservoir to do that with my mityvac... Then I noticed a pin hole in the reservoir itself...trip #2.
    Yes, its factory
    Yes its new (about a year old).
    They just don't make them like they used to...sigh.
    MP
    Marc Plante
    E36 M3/4/5 193k
    My Track Rig:
  1. Replies: 26
    Last Post: 03-05-2018, 12:08 PM
  2. Can I change coolant reservoir tank on it's own?
    By racea911 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-17-2010, 05:12 PM
  3. Anyone know where I can get instructions on changing coolant reservoir?
    By jeffrimerman in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 03-04-2009, 02:53 PM
  4. ***Noticing OIL in COOLANT Reservoir!! ***
    By mini///m3 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-18-2002, 02:35 PM
  5. Help changing coolant
    By DieselAzn in forum 1992 - 1999 M3 (E36)
    Last Post: 09-23-2002, 12:09 AM
