RM European Auto Parts
Results 1 to 3 of 3
Thread: Codes and Mass Airflow Sensor
    Sep 2018
    apache junction, arizona
    2006 bmw x3 3.1
    Question Codes and Mass Airflow Sensor
    My Service Engine soon light came on, I had the codes run and came up with the following.
    10148, 10371 (bank 2), 10370 (bank 1), 10139, 10670, p0171, p0172, p 0128, (added some coolant)in checking it is very unusual for bank 1 and 2 to both go out - which directed me to the Mass Air Flow Sensor.
    I ordered a MAF sensor, installed it and the "auto transmission" warning light came on. I put old sensor back in and its fine now (new warning light went off).
    The part I ordered was suppose to work with the E46 and M54 Engine. Mine is a M54.
    Any help on this?
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Sure: Don't buy parts at local auto parts stores. They are Chinese garbage. If you need a MAF, order an OEM part from FCP Euro, or getbmwparts.com.
    P-codes are useless, for diagnosing a BMW. You need to read codes with a BMW specific, quality diagnostic tool.....and print the descriptions, in words, as given by the quality diag tool.
    MAF codes, lean codes, and the like are most often the result of intake / crankcase vent system leaks, which require a smoke test with a smoke machine to locate or disprove.
    Chris Powell
    BMWCCA 274412
    Jan 2016
    Ca
    2001 525it
    The way the engine management systems are designed and linked to other parts of the car the fault codes that are present are not what's exactly wrong with the car sometimes. It could just be the sensor is setting faults because it's part of a system and it's the first thing in line to fault thru dx you really find out what's happening
  1. code 1215 Mass Airflow Sensor
    By dbg1ok in forum 1988 - 1996 (E34)
    Last Post: 12-11-2021, 11:23 PM
  2. for sale: mass airflow sensor conversion e34
    By papajetta in forum BMW Parts For Sale
    Last Post: 09-22-2004, 07:55 PM
  3. Wtb 95 M3 Mass Airflow Sensor
    By diddymark in forum BMW Parts Wanted
    Last Post: 05-04-2004, 06:54 PM
  4. Help with Mass Airflow Sensor
    By Motorsports in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-23-2004, 08:03 PM
  5. Mass airflow sensor
    By Revv Hard in forum 1992 - 1999 M3 (E36)
    Last Post: 03-26-2003, 07:23 PM
