Results 1 to 9 of 9
Thread: E38 M62TU code P0011
    Sep 2017
    Florida USA
    2001 BMW 740il
    Hey guys got ticking noise in engine, passenger side valve cover with error code p0011. help please.
    just hit 150000 miles
    Apr 2003
    Seal Beach, Ca.
    2003 540s, 2000 740s
    Not to pass on bad news, but search on timing chain guides to see what you're possibly up against.
    I would strongly urge you to NOT drive your car until you can find out more of what's going on (or risk further (expensive) damage to your engine).
    The only sure way to know if error code & ticking sounds are the TCGs is to drop the oil pan & look for bits of chain guide material.
    If it is the TCGs breaking up, you run the real risk of the timing chain coming loose & jumping a tooth or two. When that happens, it's very possible for the pistons to hit the valves & causing some major engine damage.
    Hope that's not the issue here, but you are exactly in that mileage range where the guides give up.
    <== Steptronic Sealbeach740
    2000 740i sport: 74k Green/Tan chrome MPars, clear corners, quad brake lights, AIC hi-beams, Hoen fogs, 16x9 screen, MKIV, TFT LCD screen in back, license plate backup camera with "on demand" switch, iPod audio/video (CDC/iPod audio switching, iPod video on 16x9 screen), Basslink, gauge rings, ///M pedals, switched steptronic +/- shifting mode, E46 paddle shifter steering wheel, Dinan engine & tranny software upgrade, DDEs controlled via Euro fog light switch, painted calipers with "BMW" lettering, windows up/sunroof close via remote.
    2003 540i sport: 81k, Sterling grey/grey, MKIV Nav, PDC & CWP - Added license plate backup camera with "on demand" switch, paddle shift steering wheel, windows up/sunroof close via remote, Akebono's, painted calipers with "BMW" lettering, quad brake lights, iPod audio via AUX mode/video via 16x9 screen, BMW TV tuner, ///M pedals & gauge rings.
    Feb 2009
    KC North, MO, USA
    1996 740iL
    Noise and that code is pretty much a no doubter. Guides. Don't run the car.
    Aug 2018
    NJ
    E38, b4 tdi
    That code and noise is how I bought mine. Almost finished the chains and guides and 1000 of other parts.
    Sent from my VS501 using Tapatalk
    Sep 2017
    Florida USA
    2001 BMW 740il
    dang. what swap you guys suggest? which engine can i put. not same M62TU..........
    Jan 2015
    Tempe, AZ
    1995 525i/5
    Swapping in anything other than an M62tu will cost a lot and require a considerable amount of skill. Swapping in another M62tu merely prolongs the issue. If your engine still runs fine, I would rebuild it and continue enjoying it for the next 150,000 miles. The chain guide replacement job is not as hard as people think it might be... but then again I'm biased as I have 16 guide jobs under my belt at this point, and am currently working on #17 and #18 at my shop.
    1995 525i 5-speed - Thread
    Sep 2012
    Miami, FL
    1997 740i
    Quote Originally Posted by amarh6455 View Post
    Dont swap. Redo the guides. Theyare plastic and they will ALL fail at some point. Where in Florida are you. I can put you in touch with someone who did mine for me.
    Sep 2017
    Florida USA
    2001 BMW 740il
    thank youguys for the advice.
    noobbiker I'm in apopka, florida
    Sep 2012
    Miami, FL
    1997 740i
    O, he’s here in miami. If you get o to the e38 Facebook site, supposedly there’s a number of folks offering it. I can PM you this guy’s number if you want to speak to him and work something out. Let me know.
  1. Fault Code - P0011
    By Wildroot56 in forum 1995 - 2001 (E38)
    Last Post: 02-21-2012, 10:12 AM
  2. Code P0011
    By Wildroot56 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-29-2008, 09:43 AM
  3. 2000 E38 error code 8C
    By 740pilot in forum 1995 - 2001 (E38)
    Last Post: 03-28-2008, 02:53 PM
  4. 1999 740il OBD Code P0011 ?
    By MishaBimmer in forum 1995 - 2001 (E38)
    Last Post: 07-28-2007, 02:21 PM
  5. 95 E38 Radio Code Please take poll if you own one
    By 740iaultimate in forum 1995 - 2001 (E38)
    Last Post: 02-17-2007, 04:15 AM
