A fiend of mine bought a ZF 6 speed E46 tranny that came in several car models, he does not want to use de dual mass flywheel so he needs the small part on the clutch master image tip after the spline of the transmisión input shaft.
How is this adaptor called? Where can he get it, and no, he has not the clutch master flywheel.
The transmisión fits the following Models
M50 3.2L, twin scroll MaximumPsi manifold +750 WHP @ 21 psi. OBDI tune, Vampire Knock controller, Racelogic TC, E46 M3 6 speed, UUC twin disk clutch, DSS new chromoly DS, DSS upgraded axles, DI aluminum intake manifold, 80lbs injectors.3" exhaust pipes with DMH cutout.
