Results 1 to 2 of 2
Thread: Power steering rack refurbishing sources.
    Feb 2004
    west palm beach, fl
    '88 M3
    Hey,
    just pulled the power steering rack from my e30 m3, because if was leaking. Are there any good and reasonable sources that i can send the rack to and have refurbished? I am located in florida.
    Thanks,
    dan
    djm1450
    Feb 2004
    west palm beach, fl
    '88 M3
    Install power steering rack
    I removed the power steering rack off my e30 m3 to have it refurbished, because it was leaking. I followed the instructions in the bentley service manual to remove the rack. The steering wheel was locked at center prior to the rack being removed. The flexible steering knuckle was attached to the rack when it was removed. I am thinking about how to reinstall the rack after it is refurbished. The bentley manual says that the install is the reverse of the removal. I don't think it's that simple. I think some added steps are required. Here are some questions i have concerning the installation:
    1) i know where the center line is on the knuckle's lower spline and rack. How do i determine where to connect the knuckle on the upper shaft? There does not appear to be a wider spline on the knuckle and shaft.
    2) should a lubricant be applied to the upper and lower knuckle and shafts? If so, what type?
    3) any potential problem with installing the knuckle to the upper shaft first and then the rack to the lower knuckle?
    4) does the the steering wheel have to be pulled and aline back to center if knuckle is off center?
    Any comments will be appreciated.
    dan
    djm1450
  1. Power Steering Rack Rebuild - How?
    By Verruckt in forum 1983 - 1991 (E30)
    Last Post: 02-27-2006, 09:30 AM
  2. FS: E36 M3 Front Subframe/Suspension/Power Steering Rack
    By Spencer in forum BMW Parts For Sale
    Last Post: 05-04-2005, 01:42 AM
  3. WTB: Power Steering rack for E39 528i (98)
    By psychocandy in forum BMW Parts Wanted
    Last Post: 08-02-2004, 10:57 PM
  4. Power Steering rack rebuild/replace?
    By Niz1 in forum 1983 - 1991 (E30)
    Last Post: 04-02-2004, 12:17 PM
  5. FS: 1992-1999 BMW E36 power steering rack
    By GFMIII in forum BMW Parts For Sale
    Last Post: 01-26-2003, 11:14 PM
