Results 1 to 12 of 12
Thread: Auto to manual swap problems
    Jun 2017
    US
    E36
    Good evening folks. I have a 95 325i with a trans from a 98 328i. Ive been watching auto to manual swap videos religiously before i started the swap. so long story short, alls thats left to do is to put the exhaust on and wire the car to start. Again, ive been watching videos and following the directions to a T, but my car wont start. you guys have any wisdom out there? ive been battling this car for a week or so now, everyday walking away defeated....i want my car back.
    I did the wiring to test the reverse lights, they worked, but when i went to put the harness on for the trans, the reverse lights didnt come on. I wanted to be able to start the car without using the clutch, yep, did that and it doesnt work. what am i doing wrong here??
    any info given will be greatly appreciated.
    Nov 2005
    SAN ANTONIO,TX
    E36,Datsun510.T-Tundra
    dont use the puter for the trans
    ...When you get a blackeye from trying to change the shift knob.
    SanDiego,Dallas,Miami,Orl
    Too Many
    At first I was doing the same as you, then I went to the local u-pull-it junkyard and got a 5-speed engine harness from a 95 325is for $35. Makes life much easier.
    Check this DIY, hes swapped and still using the auto harness
    http://e36-tech.com/DIY/5speedswap.htm
    Current lineup: 99 BMW M3vert (project) , 05 Mazda RX-8, 04 Mercedes CLK320, 03 Chevy Express 1500 (work van).
    Previous rides: 07 Mazda RX-8, 92 BMW 325iNV, 94 BMW 325iC, 94 BMW 325i S50 M3 clone, 84 Mitsubishi Cordia Turbo, 84 Mazda B2000 lowrider, 88 Toyota Tercel, 88 Honda Accord, 93 BMW 318i, 95 Nissan Altima, 89 Toyota Camry, 95 Mitsubishi Eclipse GS-T, 93 BMW 318is, 84 Toyota Tercel, 96 Mitsubishi Eclipse GS-T, 97 BMW 528i 1JZ swap, 94 Acura Integra 4dr, 88 Toyota Corolla Wagon, 97 VW Jetta GLS, 86 Toyota Corolla AE86 4A-GZE supercharged engine swap, 94 Lexus LS400, 95 Isuzu NPR Turbo, 01 Suzuki TL1000R, 98 Honda CBR600F3, 99 Yamaha R6 and countless other dirt bikes and toys
    Nov 2005
    SAN ANTONIO,TX
    lol thats my DIY , Damn its still floating around
    Too Many
    Quote Originally Posted by DEFKON99 View Post
    Yep, Im sure youve helped many!
    Nov 2005
    SAN ANTONIO,TX
    Quote Originally Posted by Richkid79 View Post
    its my pleasure
    May 2012
    Central Wisconsin
    '94 325i, '93 325is
    You say you want to start the car without the clutch pressed in but you have a 95? Have you looked at the ETM? It wasn't until later that the clutch switch prevented the car from starting, the switch was only there to disengage cruise control until a couple years later.
    Google "Wedo BMW ETM" There are ETMs for each production year.
    '94 325i Sedan, Arctic Gray: UUC LTW FW, EVO 3 and DSSR, +.020 Maxsil pistons, ASC delete, Eibach shocks/springs, 16" contour reps 238k
    '93 325is Coupe, Schwarz, work beater 299k
    '89 325i Vert, Alpine White: 5spd swapped. Sold
    '04 Toyota Sienna XLE Limited AWD, In progress swapping to M50/G250, http://www.wibimmers.com/board/index...nna-25i-build/
    '05 Volvo V70 R, 6mt, mostly stock, kid hauler 200k Sold
    '85 Toyota LandCruiser: Lifted, gas hog. 205k
    Jun 2017
    US
    E36
    hey guys, thanks for the insight. ive even followed your thread, DEFKON. step by step even before starting the swap. when you say dont use the computer for the trans, i assume youre taking about the DME. My 95 comes with 2 DME and they look different than each other. i watched a video and the dude took out the chip and plugged the DME back in. if i take my manual computer from the 98 donor, would it work then? or when you said dont use the computer, am i disconnecting one of them?
    Too Many
    Keep your engine dme plugged in (the top one) remove/unplug the trans computer (the bottom one). The dme from the 98 will not work without re-aligning the EWS
    South Carolina
    2004 330 vert 2004 X5
    Keep your auto trans harness and leave the auto tranny computer plugged in. The ASC system is wired through it. The only thing required for your car to start is to bridge the 2 wires at the auto shifter console. Join the brown wire to the black/yellow wire. No switches or anything else is needed unless you want to install a clutch safety switch. With those 2 wires connected the car should start. If it doesn’t then pull your fuses and che k them.
    Jun 2017
    US
    E36
    i went to VAC Motorsport today and they gave me an auto shifter assuming i didnt have the car in park before the swap. the only thing i would think that needs to be connected is the harness that i cut the wires off of for the reverse lights and the clutch bypass. you think if i plug this back in and move the shifter like its still auto (doesnt have the shift cable on it anymore) do you think that would work?
    May 2009
    Greenville, SC USA
    e39 M5 e39 540i6 e83 e53
    No. Do as flyfishvt says. I've done the swap on a 93 325i and a 97 M3, although I forget which color wires to connect to trick the car it's in P. If it doesn't work then you have other issues. The auto shifter won't do you any good. If connecting the 2 wires doesn't work, check fuses first, then make sure you have power at the starter.
  1. Replies: 5
    Last Post: 08-23-2015, 08:52 PM
  2. Auto to manual swap in my 328 (any problems with the diff?)
    By kpipalldaway2 in forum 1991 - 1999 (E36)
    Last Post: 11-20-2007, 10:44 AM
  3. Replies: 1
    Last Post: 02-08-2003, 03:42 PM
  4. How many hours labor for an auto to manual swap?
    By Kudo540 in forum 1992 - 1999 M3 (E36)
    Last Post: 01-19-2003, 08:46 PM
  5. Auto to manual swap?
    By RyanR6 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-23-2002, 07:08 AM
