Results 1 to 12 of 12
Thread: 325xi O2, limp, multiple codes
    May 2016
    Michigan
    2005 325xi 92k miles
    So hard to figure out where to even begin.
    2005 325xi
    Recent projects - Valve cover gasket, spark plugs, spark plug boots and the thermostat + housing.
    Was getting an O2 sensor code for about 3 weeks, bank 2 sensor 1 i believe. Along with that code was a P0174. Bank 2, system too lean.
    Occasionally getting a Misfire detected with low fuel, I've planned on doing injectors for a while. Pump is less than 1 year old.
    Now we come to last night. 8:30PM, 45 miles from home I pull up to a gas station, run inside while leaving car running. Wife was inside the car.
    When I got back in, put it in reverse everything seemed normal. As soon as I put it in drive i realized i had minimal power.
    The car when into limp mode, along with the - ABS, Yellow BRAKE light and the traction control light. Brake pad wear sensor has been on, forgot to replace sensor.
    At this point I cleared the codes with my Bluetooth scanner to see what would come back. It became a game. Some codes came back, others vanished and didn't return.
    I drove the car home, as limp mode felt like it was around 4th gear.
    Scanned it today with a snapon solus scanner and learned a bit more.
    Codes that came back were
    p0031 - HO2S heater control circuit low Bank 1 Sensor 1
    p0037 - HO2S heater control circuit low Bank 1 Sensor 2
    p0051 - HO2S heater control circuit low Bank 2 Sensor 1
    p0057 - HO2S heater control circuit low Bank 2 Sensor 2
    p0600 - Serial communication link
    And the new issue -
    Electronic Transmission Control (EGS) Signal.
    At a loss, not sure if I should change all of the O2 sensors or worry about the tranny code,
    Before clearing codes
    After clearing codes and driving home for lunch
    May 2016
    Michigan
    Small update about the O2 sensors. Grabbed a couple screenshots of the voltages while driving a few moments ago. Not sure if it helps any, I was just curious.
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    What is your fuel pressure? Vacuum leaks? Intake boots? Lean conditions can cause all.of that including limp mode.
    Don't worry about the upstream O2 voltages. They are supposed to switch from 0.1 to 0.9v back and forth really fast.
    May 2016
    Michigan
    Found 1 very small tear just behind the MAF earlier. Ordering a new boot tomorrow morning. Also found a very dry hose that is starting to crack, i believe its the secondary air valve, not sure how important it is though. Will monitor fuel pressure in the morning.
    Planning on injectors within a week, and honestly have no idea when the fuel filter was last changed. I bought the car at 92k miles, currently 141k and I haven't done it. Might as well add the fuel filter when i do injectors.
    I should note that while the computer detected misfires, I have felt nothing.
    Mar 2015
    west chicago il
    01 E46 330i 5sp man spor
    Fuse f4 in the dme box powers all o2 sensor heaters and also the trans control module. It's probably blown. It's a 30A fuse in the fuse holder shown in the picture.
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    May 2016
    Michigan
    Fuse was blown. Replaced and it popped in 2 seconds.
    Mar 2015
    west chicago il
    You have a short circuit somewhere. You recently replaced the vcg. Check for o2 sensor wires pinched under the vc, especially in the back of the engine.
    Mar 2015
    west chicago il
    Here is the wiring diagram.
    https://www.newtis.info/tisv2/a/en/e...xi-lim/jou3I3I
    Nov 2011
    nil
    nil
    I'm with the others, replace the fuel filter/regulator. I'd also take care of the vac leaks before addressing O2 sensors. I just replace the intake gaskets, injector o-rings, all crankcase vent hoses, vac hoses, and ccv on our 330xi which really helped smooth things out.
    I'd previously replaced the fuel filter/regulator and pump assembly. We were having a couple o2 sensor codes, but they went away(knocks on wood). Our car only has 67k on it. Hope this helps.
    Regards
    Mar 2015
    west chicago il
    Quote Originally Posted by por911 View Post
    Regards
    The car is blowing the fuse for the o2 sensor heaters/trans control module. Transmission in limp mode. This needs to be fixed FIRST. Then look for vacuum leaks ect for lean/misfiring issue
    May 2016
    Michigan
    Next step is the intake boot, fuel injectors and filter. If i started ordering that much stuff now, fiance would murder me. Wedding is next Friday. After that, ill start replacing more
    Started looking at the o2 sensor wiring after work. Noticed immediately the wiring for bank 2 sensor 1 was sitting on the exhaust manifold. Must have forgot to clip it back up.
    Repaired the melted wires and it runs great again. Not a single code.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    After the wedding your life will drastically change!!! Trust me!
  1. If onI o2 sensor fails could it throw multiple codes?
    By mike8668 in forum 1995 - 2001 (E38)
    Last Post: 08-06-2015, 04:23 AM
  2. Replies: 3
    Last Post: 06-04-2015, 02:16 PM
  3. Pre-cat O2 sensor heater code
    By 98technovlt in forum 1992 - 1999 M3 (E36)
    Last Post: 05-12-2004, 10:06 PM
  4. Should I buy 02 325XI with these defect codes
    By Apollothedog in forum 1999 - 2006 (E46)
    Last Post: 03-01-2004, 07:17 PM
  5. O2 sensor error codes
    By cos M3/4 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-20-2003, 01:34 PM
