Results 1 to 5 of 5
Thread: Front Crank Seal Puller Not Working - Any Tips?
    Feb 2008
    San Francisco, CA
    Jet Black 2003 M3 Coupe
    So the belt shredded on our e90 2007 328i, so I need to pull the front crank seal out because it was pretty much destroyed by the belt going behind the pulley...
    So much so that the screws that go through the seal puller to grip the seal are totally just slipping right over the seal and not getting any bite on what remains of the seal to pull the damaged seal out.
    Any suggestions on another method to get the old seal out?
    Picture of what i mean is attached.
    FOR SALE:
    *E36 "Luxury" Side Skirt - Cosmos Black - $100
    Feb 2008
    San Francisco, CA
    I've never used one before but would something like this work just to pry it out?
    https://www.autozone.com/test-scan-a...ller/48199_0_0
    FOR SALE:
    Jun 2017
    Denver, CO
    '08 E90 335xi manual
    Have you pulled the oil pan and/or valve cover yet?
    Are you gonna eat that?
    Jan 2016
    Ca
    2001 525it
    The crank seal tool I believe is like a threaded thing you insert to grab the seal be prepared to pull the oil pan there's probably bits of belt in there also.
    You've probably got a lot more damage than just replacing the seal.
    And you should probably use the BMW special tool. It works.
  1. Replacing front crank seal...question and tip
    By 1999750il in forum 1995 - 2001 (E38)
    Last Post: 11-18-2017, 05:52 PM
  2. Aux fan not working, any tips on diagnosing...
    By madsedan in forum 1992 - 1999 M3 (E36)
    Last Post: 01-26-2005, 04:56 PM
  3. LCD on the date/time does not work - any clue ?
    By Injun///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-01-2004, 05:14 PM
  4. Replacing Front crank seal.
    By jmargo in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-18-2003, 11:46 PM
  5. Change out front crank seal ?
    Last Post: 12-18-2002, 02:34 AM
