My 525it has an oil leak that keeps coming back after replacing the oil filter housing gasket. I'll replace it, but then it will start leaking again after a few weeks. I haven't had problems with the freeze plugs, since the leak will completely go away after the housing gasket is replaced. The valve cover was off recently, and the crankcase breather is clean. What could be causing the gasket to fail so quickly?
Damaged parts or improper tightening. Also the off-chance that your oilpump pressure regulator (deep inside the pump and probably not practical to replace on its own) is stuck, causing oil overpressure.
