Results 1 to 7 of 7
Thread: alternator again:)
    Oct 2005
    Boise, ID
    1980 e21, 1985 323i
    alternator again:)
    I took the alternator apart cleaned everything and put it back on. I noticed the shaft is missing the key that keeps everything
    in position so I tightened the nut down real good. I did not notice anything moving out of place. Belt has 1/2 inch deflection.
    Now when I check the battery the charge is 11.87 and with the engine running it shows 13.87. The light is still on!!!
    I replaced the regulator, so maybe that is not the problem. We were thinking the charge running should be 14+, so maybe
    that would keep the light on?
    What do you guy/gals think; oh yes, everything is tight and clean, but the ground from the engine to the body down there
    looks a little beat up!
    thanks,
    jm
    Nov 2007
    Sacramento, California
    1980 BMW 320i E21 M10B18
    Cool
    Try a 68 ohm 2 Watt - resistor on the D+ line- 12V exciter line and see if that works, on mine it does.
    Randy
    Oct 2005
    Boise, ID
    1980 e21, 1985 323i
    Thanks, will try that; any good place to find that resistor?
    thanks,
    jm
    monterey, ca.
    e21, e30 m3. e46 330ci
    is the light just barely glowing or is it full bright? also is it on with the key off?
    Tom D
    77 e21 - m42
    88 e30m3
    04 330 dinan3
    84 r1000rt
    02 r1150rs
    all of them gray
    14 f800gsa - red headed stepchild!
    Oct 2005
    Boise, ID
    1980 e21, 1985 323i
    Quote Originally Posted by Tom D View Post
    It is not bright, but about 1/3 of what it would be if you just turned the key to the run position. It is only one with the key
    in the run/on position.
    jm
    Nov 2007
    Cool
    Quote Originally Posted by 2002jm View Post
    thanks,
    jm
    e bay a couple of bucks
    There is one other item, get rid of the two piece pulley on the alternator and get a solid pulley with a slightly smaller diameter, this will kick up the voltage and amperage faster,, My two piece pulley broke and and I had a smaller solid pulley from a defective alternator I have kept around, same case size, I installed it and the light turns off instantly, before slightly slower--had to rev to shut it off -- no more on my 80 amp Alternator....
    Randy
    Oct 2005
    Boise, ID
    1980 e21, 1985 323i
    ok, will check out both ideas,
    thanks,
    jm
  1. changed alternator, car died again
    By centdukesfan in forum 1999 - 2006 (E46)
    Last Post: 05-10-2010, 07:59 AM
  2. alternator crap again!!!!
    By DrifterX27 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-21-2008, 09:50 AM
  3. Replies: 22
    Last Post: 01-06-2008, 12:40 AM
  4. Hello Again : Fuel and Alternator Problems
    By SLoWz3R in forum 1975 - 1983 (E21)
    Last Post: 03-19-2007, 11:34 PM
  5. alternator dead AGAIN!!!
    By Z3speed4me in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-09-2005, 02:08 PM
