Hello there!
Been owner of Mini Coopers (love it) and now a WRX hatchback with sti widebody swap... but now a friend of me offer me his new toy...
2000 E36 323ti awesome yellow with S54 engine and E46 dash clock swap...
Will be a nice project to own???
The body and interiors are really in good shape, but the engine doesnt feel really fast, but the sound it offer at 8k rpms... my god, WOW....
And the dash clock isnt working well maybe need some work there...
Price?
$8,766 us dllr
Some pictures...
And... will it be an awesome daily project car??? or better run out.
I would definitely like this car.. Should be seriously fast also, 343 HP, very rev-happy engine, manual transmission, in the light 323ti chassis..
If the car and engine are in good shape, then it isn't expensive, as it's virtually impossible to build a project like that for that price.
You'd need to buy a good chassis, do the needed upgrades, and buy the S54 engine ($$) and make sure it works in the E36 chassis.
If it really doesn't feel fast ("fast" is very subjective though), then it would be good to do some tests on the engines and perhaps a dyno. The S54 engine is the most expensive part of this car, so it had better be in top shape.
It should be a lot faster than the 2008 WRX as it has way more horses and the car weighs less.. The WRX will have more torque down below though, due to the turbo.
1997 E36 BMW 323i (European) 275k km (171k miles), with following small mods:
- Chip tuned DME (190HP/257Nm); 328i dual pipe exhaust (plug&play); Meyle HD control arms, Bilstein B4 shocks
- Fan delete mod: Stock 92C thermostat, 80/88C temp. switch, 80/20% water/coolant; INPA says temps 100% OK
- Throttle body coolant hose delete mod; Comprehensive ASC Delete option list; Solved: -30 additive adaptation values
If he beat on the car then the crank bearings might be toast, I don't know if that effects power or not. but something to consider.
WOW! Yellow looks really good on the shorter car....and an S54!!! Me want!
Current lineup: 99 BMW M3vert (project) , 05 Mazda RX-8, 04 Mercedes CLK320, 03 Chevy Express 1500 (work van).
Previous rides: 07 Mazda RX-8, 92 BMW 325iNV, 94 BMW 325iC, 94 BMW 325i S50 M3 clone, 84 Mitsubishi Cordia Turbo, 84 Mazda B2000 lowrider, 88 Toyota Tercel, 88 Honda Accord, 93 BMW 318i, 95 Nissan Altima, 89 Toyota Camry, 95 Mitsubishi Eclipse GS-T, 93 BMW 318is, 84 Toyota Tercel, 96 Mitsubishi Eclipse GS-T, 97 BMW 528i 1JZ swap, 94 Acura Integra 4dr, 88 Toyota Corolla Wagon, 97 VW Jetta GLS, 86 Toyota Corolla AE86 4A-GZE supercharged engine swap, 94 Lexus LS400, 95 Isuzu NPR Turbo, 01 Suzuki TL1000R, 98 Honda CBR600F3, 99 Yamaha R6 and countless other dirt bikes and toys
I want...wowza.
