Results 1 to 3 of 3
Thread: Dome light dims but does not go off
    Aug 2018
    Alden, NY
    96 BMW Z3
    Looking for some help in my 96 Z3 dome light. I read the threads but can’t find my problem. I replaced the dome with a sylvania LED bulb. It is a pretty cool blue color.
    When the doors open it turns on bright. When the doors close after a pause they dim but stay lit. From a distance in the dark you don’t notice it is still barely lit. Will this drain the battery? Is this because I used an LED bulb? I don’t think it’s the striker because it dims. Any input is appreciated. I am new to this car and have learned so much from this forum! I use to restore fiats.
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    I put in an LED bulb five years ago. I think it was this one:
    https://www.superbrightleds.com/more...car/2161/4950/
    It dims for a few seconds and goes completely out. An incompletely dimmed LED probably draws so little current that it would take a very long time to drain the battery.
    I guess the dimmer function is in the receptacle. Maybe the dimmed LED draws so little that the dimmer thinks it's out.
    Put the incandescent bulb back in and see if it goes out.
    BMW MOA 696, BMW CCA 1405
    Far Hills,NJ
    '00 Z3 2.3 Roady, '08 M5
    I had the same problem with the Sylvania bulb. I took it out and returned it. It’s not suppose to do that. I bought a different no name made in China brand from Pep Boys and it worked fine. Check the isle where they sell the Too Fast Too Furious stuff.
    On on a side note my dorm light works fine when the door opens and closes, but won’t turn on when I press the button to manually turn it on. Can it be that the switch needs replacing?
  1. E38 Check engine light in cluster does not light up
    By tobe1424 in forum 1995 - 2001 (E38)
    Last Post: 07-26-2015, 01:34 PM
  2. Oil pres light on dash does not come on when I turn the key
    By TDIpower in forum 1983 - 1991 (E30)
    Last Post: 09-29-2014, 09:00 PM
  3. Dome lights dim but don't turn off Reverse lights on.
    By kvangenechten in forum 1988 - 1994 (E32)
    Last Post: 03-15-2010, 11:19 AM
  4. Dome light does not work on drivers side .why?
    By vteckilla in forum 1983 - 1991 (E30)
    Last Post: 12-27-2005, 11:19 AM
  5. Replies: 13
    Last Post: 01-21-2005, 02:55 AM
