Results 1 to 17 of 17
Thread: Gas smell in car after parking
    Del Mar, CA
    91 850i, 01 740i, 06 760
    Driving car to work in morning I don’t smell anything.
    After being parked all day I smell gas shortly after heading home.
    I only drive it once a week.
    Just replaced all the fuel lines under hood and no difference.
    I can’t smell anything when I sniff around under hood.
    Smell is only present if I have vent fan on. If I turn off there’s no gas smell.
    About the only fuel lines I’ve not replaced are the ones above gas tank.
    Fuel pressure normal and I don’t really notice any difference in bleed down between the 2 pumps.
    Any suggestions how to locate the source?
    Thanks!
    update: After tightening a few hose clamps on gas lines at rear of engine the problem seems to be resolved. One in particular was not very tight.
    Sunny Cali,
    6.5 second 69 Camaro
    Could be a bad clamp on the one's near the firewall, Could also be a clamp or hose on the fuel filters, Best to find it and not drive it. Usually there's a white run on the rubber lines where the leak occurs, Finding them in the auctions burnt use to be very common before the DIy fixes here and RF got popular. Also check your canister and fuel pressure regulators for dampness.
    Dec 2009
    MD
    91 850i
    Is the gas smell strictly inside the car or present near the filters as well? If you've checked the hoses in between the filters for any leaks, the next thing would be to inspect the fuel pump and fuel tank sender seals under the rear seats. Also, the fuel tank vent valve may not be functioning correctly and you may have an overpressurized tank, causing bleedoff through the fuel pump seals into the cabin...That last one might be a stretch of the imagination but not an impossibility.
    1991 BMW 850i / ZF4HP24 E/H
    Oct 2008
    Mt. Dora, Florida
    Alpina B12 5.7, 850 CSi
    Be very careful with the gas smell. We had a fellow board member that ended up being able to roast marshmellows over his 8 (he was the original owner), and it burnt to a total loss from a leak from the lines leading to the gas tank.
    Check and change the fuel lines at the left rear (driver's side) of the engine. They can be a pain to change, but much better than a toasted 8. Also check the lines on the tank, which are located under the right rear seat under the circular cover.
    Editor, E31 NEWS - BMWCCA E31 Chapter Newsletter
    North America Representative, 8er.or Board of Directors
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    and also the ones from fuel pressure regulators to charcoal filter, hose 19 and 20 https://www.realoem.com/bmw/enUS/sho...diagId=13_0603
    had that last year leaking there when I installed new fuel pumps and the new ones with real good pressure and flow showed me where the leaks were. Did not leak with the old almost 30 years old fuel pumps.
    That was on my E32 750. I tested it without engine running. Ignition off, cover from fuse box off, a small wire to connect between B+ post and fuses 23 and then 24, just a short time, then the fuel pumps start and put the fuel hoses under pressure
    SHOGUN'S TRICKS AND TIPS FOR THE SEVEN SERIES
    http://twrite.org/shogunnew/topmenu.html
    Jun 2013
    Auckland, NZ
    1994 E31 850CSi
    Here is what I found when chasing a slight fuel seepage on my CSi recently.
    The bottom of the fuel tank under car was damp with fuel, and there was a fuel smell in the cabin.
    Fuel was weeping back along one of the pump hoses (shown) and was pooling in the tank/sender unit housing before spilling over onto the tank itself, then flowing down the tank to the bottom where it was visible from underneath the car.
    Fortunately the two factory fuel pump/sender unit hoses on my car (March 1994 build) were installed with neat hex-drive hose clamps, so I didn't have to cut any holes in the floor to access the two forward clamps!
    All four hose clamps were somewhat loose, with the two (concealed) forward clamps requiring about 1-1/2 turns each using a tiny ignition spanner/wrench to fully tighten them again.
    The two aft clamps took about a half-turn each.
    Both rubber hoses were still in good condition.
    Some damage is evident on the pump locking ring, from installation ex-factory.
    I could tell this was the original pump installation, as I had to cut out the factory sound-deadening material to get access to the cover plate.
    Current:
    1994 E31 850CSi Sterlingsilber/Anthracite Buffalo
    Previous:
    1987 E28 M5 Delphin
    1986 E23 M745iA Arctic Blue
    1986 E24 635CSi Polaris
    1976 E3 3.0 Si Arctic Blue
    Dec 2009
    MD
    91 850i
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    That's a really tidy solution!
    Mar 2006
    Harrisburg, PA, USA
    x5, 640i, 850Ci, 850CSi
    I like it. Where did you get the rubber grommets?
    Mike Barrett
    94 850CSi, Hellrot over silbergrau dunkel/silbergrau hell
    96 850Ci, Oxfordgrun over silbergrau hell
    Jun 2013
    Auckland, NZ
    1994 E31 850CSi
    Yes a good looking solution.
    Luckily I didn't need to replace my hoses, so no need to cut any holes in my car.
    Thanks to BMW's factory orientation of the two forward hose clamps, I could reach them both and tighten using the aforementioned ignition spanner.
    Current:
    Previous:
    1987 E28 M5 Delphin
    Oct 2005
    Plantation,Fl
    13 Focus ST e38 soon
    Quote Originally Posted by rogbmw View Post
    Hey Roger a bit off topic but I saw an old post of yours while looking up import information about a CSI. Your post was about the b12 being able to come stateside thanks to you and Bill Fox. I assume that is also the case for other e31ís including the CSI? I found is a 96 in Germany and want to bring it to Fort Lauderdale as a gift for my dad who to this day still pines for the car. If you have a link to a thread where youíve gone over what you had to do for importation headlights, reflectors, epa etc and if they make a fuss about the AHK. Any information you could give me here or in a message would also be greatly appreciated! Thank you!
    Calgary, Canada
    '91 E31 850i,'05 E53 4.4
    Quote Originally Posted by mbarrett635 View Post
    I would also like to know as I JUST had to tighen these damn clamps after new fuel pump carrier install and it took sooo much contortion on my body to finagle a pair of long needle nose pliers under the metal opening and will probably want to tighten them again a bit more for peace of mind but yes a hole drilled out would be KEY.
    I swear, my cars are like a girlfriend.
    Sometimes its a rough ride, sometimes its smooth motorin'.
    Sometimes she doesnt like how i treat her and sometimes i dont like how she behaves.
    BUT at the end of the day, she loves it when I am inside her.
    Jun 2013
    Auckland, NZ
    1994 E31 850CSi
    This type of wrench does the trick (forget the size I used) - no need for pliers, or cutting holes in the car unless the clamps have been rotated out of reach.
    Getting at them still requires a degree of contortionism though.
    Current:
    Previous:
    1987 E28 M5 Delphin
    Dec 2009
    MD
    91 850i
    Those are generic rubber grommets that can be sourced from anywhere (Digikey, Mauser, etc.) In the automotive industry they're typically called just "blank firewall grommets" and can be bought in a variety of sizes. I ordered the grommets off eBay in a very specific size, and then matched a holesaw to the size of the grommets, ensuring that I would have a perfect fit.
    Mar 2006
    Harrisburg, PA, USA
    Thanks!
    Mike Barrett
    Iceland
    BMW 850
    Quote Originally Posted by mjrgroup View Post
    Good to see you are still around. Any new stuff happening to your car?
    Calgary, Canada
    Thanks for the idea.
    I just drilled two 2" holes and painted the edges of new holes. So nice/necessary for access.
    Checked hose clamps. A little loose but not much.
    Waiting for rubber grommet blanking parts to be installed.
    This should have been designed like this from factory!!
  1. gas smell in car after it sits for a while
    By BMW750il&AudiA6 in forum 1988 - 1996 (E34)
    Last Post: 07-27-2012, 11:53 PM
  2. Help: Gas smell inside car!
    By DocDuvi in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-09-2007, 10:30 PM
  3. Gas smell inside car
    By Casebrius in forum 1996 - 2003 (E39)
    Last Post: 12-28-2005, 02:08 AM
  4. bad gas smell in car
    By lsmkr06 in forum 1983 - 1991 (E30)
    Last Post: 11-20-2004, 10:16 AM
  5. Gas smell when car is driven hard...
    By manny in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-21-2003, 05:15 PM
