Results 1 to 24 of 24
Thread: Clutch Master Cylinder Upgrade?
    Jul 2002
    Long Island, NY
    98 Turbo M3, 04 E53 X5
    Does anyone know is there is an upgrade for the stock M3 clutch master cylinder?
    98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
    2017 Toyota Tundra Crewmaxx - Family Whip
    2011 Pierce 75' Quint - Fire Apparatus West Islip FD
    Apr 2006
    Minnesota eh?
    86 325es
    What are you looking to gain from it?
    Mar 2012
    Renton, Wa
    98 m3
    You can run an 850il cylinder.
    Or swap over to the twindisk with the gs6, it’s night and day.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
    Jul 2002
    Long Island, NY
    Believe I might of blew the clutch master cylinder...using a FX850 clutch with a hydraulic bearing...I dont see any leaks anywhere. You can exercise the clutch but as soon as you hold it down for a sec it stays to the floor. You can hear the clutch disengaging while its pressed in but then it goes back on its own still while the pedal is down. Then the pedal stays down.
    Quote Originally Posted by vollosso View Post
    Tell me more about the 850il CMC?
    Aug 2002
    KS
    M3, Range Rover SC
    Might be a dumb question but does your car have a CDV?
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    He joined a month before you in 2002. I bet NY98M3 knows what a CDV is.
    Aug 2002
    KS
    M3, Range Rover SC
    I see. Well he would also probably know that an 850 CMC wouldn't help either if that were the case. Likely a slave cylinder but in his situation that wouldn't be of any benefit with a hydraulic TB. Carry on.
    Jul 2002
    Long Island, NY
    Quote Originally Posted by Iding SIII View Post
    no it does not
    Im an old man lol
    Jun 2005
    New England
    If it’s a fairly fresh master as opposed to a 20 year old one, he may have blown it with the hydraulic TOB conversion. It probably takes some trial and error on line size and SMC size and pedal trace to set up perfectly for a particular clutch and the research may not exist for these parts on an E36M3. If he did blow a fresher SMC, changing the pedal stop might be easiest part to experiment with.
    Aug 2002
    KS
    M3, Range Rover SC
    I don't know if I would call it an upgrade but I went with the aluminum master to replace the plastic one because I will also be using a hydraulic TOB.
    Los Angeles
    '96 328iC, '89 325i
    In for info
    I also have a hydraulic TOB and clutchmasters 725 twin disc (LOVE IT) and have been chasing weird disengagement issues for a while. I've replaced the master twice, both OEM aluminum units and at this point I kinda get the feeling that the OEM master just can't handle the forces of the twin disc? Issues I have are inconsistent disengagement/engagement point where the clutch will grab at different levels. I usually have to use my toe to pull the pedal all the way out an additional ~1/4" to get proper operation. Thinking of using a small spring to help me do that... still irritating and I've been bouncing the idea of an aftermarket MC in my head even if it required modifying the pedal bracket to mount. This way I could also choose the MC size for a lighter pedal and a bit more travel.
    '96 328iC, '96 328i, '89 s52 swapped 325i
    Shadetree30
    Aug 2002
    KS
    M3, Range Rover SC
    Quote Originally Posted by cpalella View Post
    In for info
    Excellent info you've provided. I saw these images floating around a while ago on the Facebook pages of one guy who modified the pedal assembly to use a Wilwood MC but thought it would be overkill. After hearing of your issues I'll probably remove my pedal assembly and do something similar with the Wilwood compact remote side mount master cylinder 260-12387. The piston stroke length is almost identical to OEM but I'll have to figure out the correct bore size. Might contact Clutchmasters to see what they recommend.
    Jun 2005
    New England
    Do you think the hydraulic TOB is causing the issue or the twin disc or the forces of the twin disc? Do the many people with the UUC twin and standard slave piston fork pivot have issues - I recall complaints but not sure the subject matter is the same. BMW used a twin disc on the E90M3 with standard slave piston. Maybe that master could work? Obviously that is a twin organic with less clamping force. A twin 7.25 might also need more clamping force than a twin 8.5 to hold the same power.
    Dec 2007
    SF bay area
    1998 M3 / 2000 S2000
    deleted
    Wanganstyle Powertrain
    http://www.wanganstyle.com/
    S54B32 E36 M3 DTA S100 Sedan Street car full swap:
    http://forums.bimmerforums.com/forum....php?t=1437471
    Los Angeles
    '96 328iC, '89 325i
    This is interesting! Thanks for the photos. E30 pedal bracket is a little easier to work on since it's steel I can just bend and weld whatever bracket is necessary. Good idea to call clutchmasters
    Don't think it's the hydraulic tob. I had nearly the same issues before I installed it and was using the regular pivot fork and tob. The clutch itself is definitely a factor. It's stiffer than oem by like a factor of 3 or 4. Also has a super short engagement/stroke. Like 1"-2"
    Quote Originally Posted by wanganstyle View Post
    the master cylinder from a e32/34 735i-5 and 535i-5 speed looks really similar to the e36 and e30 physically, its also metal. might be larger bore
    just looked it up, at least for me it's no change. Still a 19.5mm same as what's already in my e30
    Shadetree30
    Jul 2002
    Long Island, NY
    In for info
    Do you find that the pedal has no pressure on it until about 1/4 the way down? I found my issue but was wondering if yours had the same feel.
    Mar 2012
    Renton, Wa
    98 m3
    Do you think the hydraulic TOB is causing the issue or the twin disc or the forces of the twin disc? Do the A twin 7.25 might also need more clamping force than a twin 8.5 to hold the same power.
    Good news for you is you don’t have any of these issues and similar holding force! Did you install that clutch kit yet?!
    It’s funny the way clutches work, the 725 has lesser area meaning it needs less pressure or less clamping force to create the same holding capacity. But since it’s smaller you have less diaphragm to use as a lever and so the pedal force goes up! Even though the diaphragm is either the same clamping or less clamping for similar capacity!
    1989 535i - sold
    Aug 2002
    KS
    M3, Range Rover SC
    Quote Originally Posted by NY98M3 View Post
    How is the pedal effort past that 1/4 way point?
    Jul 2002
    Long Island, NY
    feels fine, had to make a longer pedal stop to it doesn't overstroke
    Aug 2002
    KS
    M3, Range Rover SC
    Thanks, good info I'll probably order a master with a slightly smaller bore size to increase pedal travel.
    Oct 2005
    Northern California
    95 M3, 15 Golf TDI wagon
    NY98M3, did you end up trying a Wilwood master cylinder?
    -WTB: OEM Class 2 LTW GT wing with risers- Mazak
    Mar 2016
    Carson city, Nevada
    97 E36 Sedan, 95 525i
    +1 Would also like to know about the wilwood cylinder..
    Jul 2002
    Long Island, NY
    Quote Originally Posted by 3literheater View Post
    Quote Originally Posted by E36KDrift View Post
    no I didnt...it ended up be a small leak on the AN fitting in the bell housing.
    Vancouver, BC Ca
    1993 325is
    All this talk about hydraulic release bearings: are we talking about the Clutchmasters kit? Anyone have any issues with the actual release bearing kit/parts? Works as advertised? I need one for my build for clearance reasons. My trans is moved back in the chassis about 1 1/2" and now the trans tunnel isn't wide enough to clear the clutch slave. Rather than BFH mods, I thought this would be a more elegant solution. My clutch would be the FX350 at worst. I'm only looking to hold 400-450 ft/lbs max.
  1. Brake and Clutch master cylinder upgrade
    By brandonmatthew in forum 1991 - 1999 (E36)
    Last Post: 09-08-2010, 01:22 PM
  2. Clutch master cylinder replacement!@#
    By mrhmmhmm in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-10-2007, 10:26 PM
  3. M3 clutch master cylinder upgrade?
    By Geno325is in forum 1991 - 1999 (E36)
    Last Post: 01-21-2007, 01:29 PM
  4. upgraded clutch master cylinder?
    By Jason99T/A in forum 1983 - 1991 (E30)
    Last Post: 12-05-2003, 04:05 PM
  5. Symptoms of a bad clutch Master cylinder?
    By BMWM3some in forum 1992 - 1999 M3 (E36)
    Last Post: 02-09-2002, 09:57 PM
