Results 1 to 4 of 4
Thread: Proper shutting of window
    Mar 2006
    parker, co
    M3 E36, 2007 X3
    My 95 M3 has a window switch, motor or fuse that needs to be replaced as it is non-op in the up position but what is bugging me right now is that when I shut the door it does not close correctly and will shut tight then re-shut several times. I noticed if I shut the door from the outside at the right speed at a low point on the door I can get it to shut right quite often but that is beyond my skill level to do from inside the car (LOL). I think I read somewhere there is a micro switch I need to replace. I search for the post for a while but decide to just post here if you don't mind.
    Thanks again to all the great wrenches out there.
    Oct 2003
    Seattle
    99 M3
    Micro switch that controls that function is on the “B”-piller within the door catch.
    Mar 2006
    parker, co
    M3 E36, 2007 X3
    Thank you for the help, I appreciate it.
    RRSperry's Avatar
    RRSperry is offline Senior Moment Member BMW E36 M3 Expert
    Mar 2002
    Eldersburg, Md
    95 ///M3sc, '21 C8 HTC
    Yep, microswitch.
  1. How to properly install the Rear Window Spoiler?
    By JLe38 in forum 1995 - 2001 (E38)
    Last Post: 02-02-2004, 12:06 PM
  2. Driver Window not sealing properly
    By shawn w in forum 1992 - 1999 M3 (E36)
    Last Post: 12-01-2003, 12:38 PM
  3. Window isn't rolling up properly; bad regulator/motor arms??
    By Stang_ROTY in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-19-2003, 05:11 PM
  4. Replies: 5
    Last Post: 08-19-2003, 01:00 PM
