Vehicle - 1999 Z3 Roadster. The Interior light on the inside header on top of windshield has 3 positions; Light on always, Light only on when door is opened and Light always off. The interior light no longer goes on when either door is open. The other two positions operate properly. Before I start replacing the light assembly or the switches, I'd appreciate if anyone else has had this issue and a potential fix. I know there is a switch built into the door latch, but not sure if that switch applies to the Z3 as I know this same type of system is carry over from other Bimmers. Can't really find any other switch that controls interior light going on when door is opened. Also, odd that both doors suddenly stopped operating light at the same time . Thanks for any suggestions.
More likely that the overhead switch stopped working in that position.
https://www.ecstuning.com/b-genuine-...h/61318407738/
BMW MOA 696, BMW CCA 1405
Try pushing both door latch buttons all the way in. On occasion, when my interior lights time out, they don't come back on. I will push the driver's door latch button in and they work again. I should add that the button has worn down and is currently built up with some tape so that it works. A new latch is waiting to be installed.
Wayne
1998 M Roadster
1994 Honda ST1100--sold
2017 Yamaha FJR1300ES
I had this problem and it was down to corrosion in a connector that sits behind the a-post trim, that provides power to the light. No idea why, as the car doesn't leak, but maybe something from the car's past.
It would be odd for both of the OP's door switches to suddenly not work at the same time, but it is a good suggestion to look at them.
When the plastic tube over the latch rod wears down, it affects latching. For latching problems, people wrap tape around the rod, or slip a piece of slit plastic tubing over it:
http://www.bimmerforums.com/forum/sh...1#post27825111
Perhaps latching can also affect how the door pushes on the switch behind the rod. Still, closing the door depresses the switch which turns the interior light off, while the OP's problem would be the open door not releasing the switch which needs to spring out to turn the light on. As if the switch were stuck closed. Both switches.
If the door strike/switch(es) needs replacing, here's a DIY:
https://www.bimmerforums.com/forum/s...1#post25408361
Thanks for the good link to the replacement of the door striker. It is somewhat more simple than another I've seen. I will refer to it when replacing the part.
I have already placed some slit tube on the latch rod. It helped, but not enough to depress the switch reliably. Going over a bump will cause the lights to come on. The problem is that the plastic switch is worn down, as one would expect to happen when the metal part on the door continually rubs against the switch. Two small pieces of gaff tape have been enough to build the switch up temporarily, until it gets so hot outside that they peel off.
I agree that it is unlikely that both switches are stuck closed. When I have had an intermittent problem (2-3 times in two years) with the lights coming on, depressing the driver's door switch, which is not stuck in, has been the fix. I have not investigated further since I think the problem will go away with a new striker assembly.
This all makes me wonder what was wrong with the apparently antiquated American system of a plunger switch that worked independently of the latch. It wouldn't wear down, and if the switch had an electrical problem, it was easily repaired.
Wayne
1998 M Roadster
Vintage 42. thanks for your suggestions. I'll check it out on my Z. Appreciate the reply.
Florida Z3
RASMUW, Thanks for the tips. I'll also check these out.
