Results 1 to 7 of 7
Thread: Insight? First compression test
    Apr 2017
    Schenectady, NY
    1995 BMW M3/2/5
    Hey I just ran a compression test on my s50. My lowest cylinder was number 6 at around 135. 1-5 were all 140-145. I got these numbers on two tests. I'm happy to see the numbers are fairly consistent but over all is this low-ish compression on an s50 with 115k?
    Sent from my SM-G965U using Tapatalk
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    Very very low, especially at your elevation (276ft based on your location).
    Get a new tester of quality and try the test again. Make sure you are connected to a strong battery charger, the motor is warm, that you are holding the throttle WIDE OPEN during the test, and that you are cranking till the numbers peak (usually 12-16 cranks).
    Apr 2017
    Schenectady, NY
    1995 BMW M3/2/5
    Hmm. I bought the highest rated tester on Amazon. Car was at operating temperature and I had throttle wide open. My buddy said I was peaking at about 4 cranks. Each cylinder I gave it about 8 cranks
    Jan 2006
    Oakhurst, CA
    I’ve never seen any of these motors peak at 4 cranks unless using oil for ring diagnostics. I still suspect the tester.
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    OP, did you pull the fuel relay? If not, fuel will wash the walls and throw off the readings significantly.
    88M3 AW 43k miles Project FS
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    stock cams, timed correctly (ie, not too much overlap?) Numbers are low, but consistent, so that's definitely good.
    Check out the 8legs Racing page: https://www.facebook.com/8legsRacing/
    Apr 2017
    Schenectady, NY
    1995 BMW M3/2/5
    As far as internals go this is a completely stock motor. I have no idea on timing as I've never checked it. Yes I ran it for a good drive and pulled it in. Then I pulled the fuel pump fuse and started pulling the plugs
  1. Question about compression tests...
    By Jon97 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-20-2002, 02:38 PM
  2. Compression Test Results...:(
    By JasonJ75 in forum 1996 - 2003 (E39)
    Last Post: 02-05-2002, 07:32 AM
  3. Compression test anyone???
    By SilverM in forum 1992 - 1999 M3 (E36)
    Last Post: 09-09-2001, 02:38 PM
  4. Compression test anyone??
    By SilverM in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 09-09-2001, 02:24 PM
  5. Compression Test?
    By RobH in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-24-2001, 08:31 AM
