Results 1 to 9 of 9
Thread: Door sill plates
    May 2018
    Florida
    '99 E39 M5T
    Door sill plates
    I am missing my front passenger and rear driver side sill plates. Assuming they would fit, from a sedan, I scoured some from the junkyard today; only to find that they dont fit. The front passenger side may fit, but I found it to be a bit different than the ones i already have. I did manage to find another msport steering wheel, in better shape than the one i found last week. 😁
    Jul 2012
    mitten
    525it,02 525it,73 2002
    Door sills are interchangeable on a e39
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    Yep, no differences between wagon and sedan.
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    The alignment pins slide up from their correct positions when you remove/disturb them. Just make sure all your pins are in place, the holes have the little plastic wedges in place and reinstall. Simple
    Yes, some of the trim will need to be "massaged" into place. Make sure you treat them with some Armor All - 303 or whatever product you like before installing them. Then wipe off your finger prints and enjoy your shiny protection parts.
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
    May 2018
    Florida
    '99 E39 M5T
    Turns out, there were only two holes that I could put the pins in. Could not use the third pin, near the rear, because there was no hole.
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Wagon727 In the front or rear door locations?
    Snotty, Can you post a photo on the bottom side of the trim plates?
    2003 525iT TiSilver
    2002 M5 TiSilver
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    May 2018
    Florida
    '99 E39 M5T
    Rear.... There was a hole for the pin that sticks out of the plate, that just presses in. And there were three "adjustable" pins. But, I only had holes for the two most forward adjustable pins ( looks like they were drilled). But no hole for the rear most pin. I did install the plate, but its loose at the back side. Maybe I'll just rig it and use double sided tape.
    Feb 2014
    Alexandria, VA
    Quote Originally Posted by StephenVA View Post
    Sorry Stephen, just saw this. Looks like someone did some bodywork on his door sill,
    If someone just drilled the holes, make sure you spray some wax in there to keep the exposed steel from rusting!!!
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    When in doubt just use super glue. It not like the fifth/sixth and final owner is going to worry about door scuff panels....
    2003 525iT TiSilver
    2002 M5 TiSilver
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
  1. E36 M3 door sill plates for Coupe
    By StreuB1 in forum Exterior Lighting & Body Parts
    Last Post: 01-09-2008, 04:46 PM
  2. E36 door sill plates and gauge cluster
    By PunisherMAX in forum Exterior Lighting & Body Parts
    Last Post: 09-21-2007, 06:04 PM
  3. wtb M3 door sill plates
    By PunisherMAX in forum BMW Parts Wanted
    Last Post: 09-06-2007, 02:48 AM
  4. FS: M3 door sill plates
    By bmw3er in forum BMW Parts For Sale
    Last Post: 05-19-2006, 01:12 PM
  5. ///M Aluminum Door Sill Plates
    By Scho in forum BMW Parts For Sale
    Last Post: 03-15-2004, 01:52 PM
