Results 1 to 4 of 4
    Elk Grove, CA
    2005 Acura MDX
    Off Road tires on my 2011 X5 Diesel?
    Hi all
    80k on my X35D and was going to trade it in for a Tacoma truck but decided to keep it.
    I'm looking to replace my stock tires with bigger (not wider) off road tires , if possible without any lift,mods.
    Current stock is 255/55 R18 (non staggered).
    I found this google picture (perfect for what I'm looking for) but no description on the brand/size.
    Any help would be highly appreciated!
    My current:
    My ideal:
    Elk Grove, CA
    2005 Acura MDX
    Found these which is very similar to the google pic I found above. Would these work? Thanks
    These are 265/60 R18
    https://www.americastire.com/buy-tir...-a-ko2/p/32064
    Aug 2013
    Chesapeake, va
    2002 BMW X5 4.4
    Be sure to be allowed to get a trial fit to ensure no interference with suspension or body, but 265/XX is within the OE cross section sizes.
    Be sure that fronts are same rolling diameter as rears.
    The speedometer readings will be off, so shift points may need to be adjusted, but you can always run around in sport.
    Sent from my Moto Z (2) using Tapatalk
    Northwest Ohio
    2001 750iL
    This was the best rated tire I could find for my truck (Excursion). The diameter is spot on at 29 inches.
    https://www.tirerack.com/tires/tires...8KO2&tab=Sizes
    2005 X5 4.8is (DD winter) * 2001 750iL (DD summer) * 2001 Ford Excursion 7.3 L <> 2005 X5 3.0 * 2003 X5 4.4i * 2009 X3 3.0 * 2009 X5 3.0 * 2007 Toyota Avalon Limited
  1. 2011 X5 Diesel..check engine light and fans not working!
    By SSingh1975 in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 04-17-2017, 12:34 PM
  2. 2011 X5 diesel
    By Hungarian E30 in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 09-09-2016, 02:00 PM
  3. DIS won't connect to a 2011 X5 diesel
    By Thirdy in forum Diagnostic Software
    Last Post: 01-06-2014, 05:21 PM
  4. Replies: 1
    Last Post: 10-23-2012, 06:46 PM
  5. 2011 X5 Diesel on Order!
    By ddsski in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 05-08-2011, 05:37 PM
