Results 1 to 8 of 8
Thread: Idle surging and car shutting off
    Sep 2016
    San Diego, Ca, usa
    1994 Bmw 525i
    I have a 94 525i with 267k miles. The check engine light has been on for a while. I was getting the code for the MAF. I replaced that today and the CEL went off immediately, however, it started having a surging idle when I let go of the gas pedal. When I come to a complete stop, the car starts to surge and even surge forward even if I have my foot on the brakes. Sometimes the car just shuts off when I come to a stop. And sometimes the CEL will come back on after the engine surging. I haven't done the stomp test again yet, but will do tomorrow.
    Any suggestions on what could be the problem?
    Jan 2017
    Carrboro, NC
    '91 525i (5sp)
    Unfortunately, those symptoms are relatively common to many issues... That said, it sounds very similar to my experience with a bad oxygen sensor: idle surges, intermittent CEL, stuttering, although mine wasn't shutting off; sometimes I was able to make the CEL go away by shifting to a higher gear (when possible), you could try that if yours is a manual, just to check.
    If the stomp test shows no codes, I'd try and get a good used oxygen sensor, or at least a cheapie generic one, just to rule it out; if that doesn't work, throttle sensor and idle control valve would be my next suspects. As I mentioned, there's a couple other things that can show similar symptoms (even a bad ECU!).
    Hope this helps, and good luck!
    Sep 2016
    San Diego, Ca, usa
    1994 Bmw 525i
    Quote Originally Posted by The Chauffeur View Post
    Just did the stomp test. Got codes: 1215 Air Mass Sensor
    1216 Throttle Potentiometer
    Is the Throttle pontentiometer also a name for the TPS or is it something else?
    Apr 2016
    Santa Clara, Ca
    1993 525i
    Where did you get your MAF? If you bought a cheapy on ebay verify that the construction in the airflow area is identical to the one you removed. The cheapy I bought on eBay was the hot wire type and not the hot film type that was required. I had all kinds of surging problems with the ebay cheapy. Luckily, Ross sold me a good used one here in the forums that was the proper hot film type and it solved the problem. Still working great today. The only other thing I can think of is a vacuum leak somewhere. A smoke test will help you find it.
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    Jan 2017
    Carrboro, NC
    '91 525i (5sp)
    Quote Originally Posted by moroza View Post
    Stay away from generic O2 sensors.
    "or at least a cheapie generic one, just to rule it out" :|
    Sep 2016
    San Diego, Ca, usa
    1994 Bmw 525i
    Quote Originally Posted by Ardvaark View Post
    Yea, I did get it from ebay. :/ It looks just like the one I have, but it has a thin wire (think of the wire in a lightning) coming from one end of the hot film to the other. My old part doesn't have that wire. Is it supposed to have that wire?
    Sep 2016
    San Diego, Ca, usa
    1994 Bmw 525i
    Here are pics of the two. The first is the new one and the second is my old one.
  1. e30 rough idle leading to car shutting off
    By lowseven in forum 1983 - 1991 (E30)
    Last Post: 04-04-2017, 09:24 AM
  2. my car shuts off at idle when warming it up!!!!
    By bimmerguy in forum 1996 - 2003 (E39)
    Last Post: 02-14-2007, 10:56 PM
  3. idle bouces and car shuts down
    By CEbeling in forum 1992 - 1999 M3 (E36)
    Last Post: 09-16-2006, 12:51 PM
  4. Why does my car shut off while idling?
    By B.Lin in forum 1991 - 1999 (E36)
    Last Post: 03-04-2006, 12:59 AM
  5. 92 318is w/170k - Idle Surge = Shut Off
    By 8psi318 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-11-2002, 09:25 PM
