Results 1 to 5 of 5
Thread: Best sub-frame / suspension bushing brand / grade for e36 street care
    Sep 2018
    Houston, TX, USA
    1999 BMW Z3 Coupe 2.8
    Hi all, looking to do a sub-frame / suspension bushing replacement (front and rear) on an e36 for street use. Anybody have recommendations on a brand of bushing that they have had luck with?
    I like the idea of something high performance but most importantly something that will keep the sub-frame in good shape.
    I'd like to pay a bit extra and have them last if that is possible.
    Aug 2013
    1999 BMW M3 Coupe
    Lemforder OEM. Any sort of poly is going to introduce more NVH, so it's best to stick with OEM in any street-only car. If you replace all the old bushings and ball joints with new OEM rubber, the car will feel nice and tight and will be set for another 10+ years on the street.
    If you really want to go poly, the places you can do it with the least impact to NVH are probably the rear subframe/diff. You'll get some degree of diff whine and vibration going poly on both, but you may be able to avoid it if you leave rubber on one or the other. Do not use poly RTAB's, and I strongly discourage poly motor/trans mounts on street cars.
    Sep 2016
    Amesbury, MA
    E90 328i
    I agree with TostitoBandito, if it is street only I would use OEM type bushings. If the bushings are original anything at this point will be an upgrade!
    Here is a front and rear overhaul- https://www.turnermotorsport.com/f/C...esrep=skothman
    Feel free to contact me directly with any questions!
    Sean Kothman
    Sales | Turner Motorsport
    800-280-6966 ext 139 (toll free)
    978-388-7769 ext 139 (intl)
    / // Parts & Performance for BMWs
    www.TurnerMotorsport.com
    Seank@turnermotorsport.com
    Sep 2018
    Houston, TX, USA
    Things to consider. Thank you, gents!
    FL
    are slow.
    OE bushings. The only mount I would consider making poly would be rear subframe mounts, but for a 100% street car? I would still go OE.
    The original bushings have a lifespan of around 100k miles (depending on environmental conditions too), so new OE mounts should give you around 10 years of use.
    -Dr. Seuss
  1. Best Sub-$1K Suspension
    By TheTynosaur in forum 1991 - 1999 (E36)
    Last Post: 07-08-2014, 05:33 PM
  2. Best sub-$1k suspension
    Last Post: 07-01-2014, 12:27 AM
  3. E39 sub frame & suspension
    By ross1 in forum Suspensions, Springs & Shocks
    Last Post: 10-27-2010, 09:10 AM
  4. suggestions on sub frame & TA bushings
    By wastedincome in forum 1988 - 1996 (E34)
    Last Post: 04-18-2009, 08:14 PM
  5. Rear sub-frame mounting bushes
    By MCAnick in forum 1975 - 1983 (E21)
    Last Post: 06-14-2007, 06:52 AM
