Results 1 to 18 of 18
Thread: Is this E32 clutch pedal linkage torqued or normal (pic) ?
    Oct 2008
    Belgium
    E32 M30 01-1987 Manual
    Hi all!
    Total noob on cars here, trying to fix broken clutch on a cool E32 that I inherited
    So after finding that the clutch master cilinder was broken. When installing a
    new one, I found that the linkage of clutch pedal that links up with master
    cilinder "push rod thing" seems torqued.
    Here is a pic of the old broken master cilinder in place, the master cilinder connection
    is broken, and also seems like clutch pedal linkage is twisted :
    Here is a clear picture of clutch pedal linkage, it seems like there's no way you can
    correctly connect with then new master cilinder that way :
    When looking up a pic of OEM clutch pedal assembly it also shows up straight,
    although be it with a slight sort of offset in it :
    I don't know how accurate the drawing is, but you would expect it to be shown correctly,
    So anyone who has replaced master cilinder, is this the pedal linkage supposed to be torqued
    like in my pictures ?
    I think master cilinder was blocked, and my grandpa ( previous owner ) pressed it full force
    and bent the linkage it one point
    Also, reinstalling the master cilinder is a hassle.. getting the hardline attached to it (on the engine
    side of bulkhead) back in its place is a nightmare !
    cheers for any light on this guys !
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    I cannot imagine that the pedal can be bent. What is the part number in realoem based on the VIN of the car? For example if the car was built in 10/1987 the part number would be 35311155691 here is a picture https://www.ecstuning.com/b-genuine-...r/35311155691/
    But I cannot compare on an actual part, as my 740 has automatic transmission and no clutch pedal.
    change the bushings 35211158290 in any case they are usually broken https://www.realoem.com/bmw/enUS/sho...diagId=35_0056
    clutch pedal repair in 2016 and 2015 and 2014 under maintenance http://alpinakozou.web.fc2.com/index.html
    My Cars 7.30i E32
    This info in your profile is not enough, pls add built year and month and which engine. In case it is a 6-cylinder mention 730i M30, if it is a 8-cylinder mention 730i V8
    USA
    e34 540ia/e32 740il
    Woah, that is very much bent. That arm is supposed to be flat, that bracket on the clutch pedal is thick steel, I'm amazed it torqued like that! Good news is you can still buy the clutch pedal directly from BMW and it's cheap.
    Oct 2008
    Belgium
    thanks for the info guys!
    @ Shogun
    It is a 6 cilinder, 01/1987, left hand drive, manual
    Part nr from the realoem webside for clutch lever ( nr. 14 in the drawing in first post above here )
    using that info is : 35311155691
    It also states a "Supersedes part nr." : 35311155690 (06/01/1986 — 10/27/1994),
    witch I dont know what that means.. maybe this part form later model also fits ?
    ECS site shows clearly the offset as in the drawing, really helpfull pictures on that site !
    If I lived in USA I would order from that site !
    Really cool site that Japanese / Chinese one, pedal shows straight in his pics to
    @ m60power
    looks like am on the hunt for a new clutch pedal and bushings !
    Hope to find the time to try and remove the pedal box later today or next weekend
    Thanks for the tip on locktite Shogun, I went to a shop that does hydraulic lines for
    bulldozers and so on, they recommended me locktite 722.
    BTW reinstalling the clutch master cilinder with that hardline attached to it is such a nightmare
    that I am considering going back to that hydraulic line shop and see of they can whip me up
    a piece of flexible hose by maybe chopping up the original one, recovering the screws on it.
    The guy at the shop thought the screws where BMW specific.
    Although I don't know if that's a good idea or not..
    Jan 2005
    Japan
    Supersedes means replaces old part number, usually there is mentioned that it fits, 35311155690 Clutch lever , Superseded by: 35311155691 (04/01/1989 — ), Exchangeable retrospectively
    Part 35311155691 was found on the following vehicles:
    •5' E34   (03/1987 — 06/1996)
    •7' E32   (10/1985 — 04/1994)
    •8' E31   (07/1989 — 05/1999)
    That is a Japanese website of one of my wrenching friends, he has an Alpina 735 B11 http://alpinakozou.web.fc2.com/index.html
    Oct 2008
    Belgium
    Waaaaw that Alpina version looks the business !!!
    Albuquerque, NM
    way too many
    The bolt is an eccentric shoulder bolt, which allows adjustment of the pedal height. It should be tight but the eye of the master cylinder rod should be free to swivel. The lever arm on the clutch pedal has a slight jog but should be parallel to the plane of travel.
    The hard line from the tip of the master cylinder to the slave is a pain to deal with. As you may have discovered, there isn't much access from underneath the car. Best approach is to remove the two 6 mm master cylinder screws and pull the master cylinder inside the car far enough to reach the gland nut. The nut is soft, use a 6-sided flare nut wrench on it.
    ​"The US Olympics bobsled team has renamed their sled 'Biden' because nothing has taken America downhill faster"
    TheStigg (aka "gale")
    92 735i 5-spd, turbo pending
    89 535i 5-spd (may she rest in pieces)
    94 325ic 5-spd
    87 325is
    Albuquerque, NM
    way too many
    Obviously something froze or popped out of place on the old master cylinder to cause the lever arm to twist out of plane. You may be able to bend it straight again by grabbing it with a crescent wrench. When you have the new master cylinder installed and bled, there shouldn't be that much force in operation to cause it to bend again. Just take a close look at the welds after you straighten it to make sure they aren't cracked and the lever appears straight and solid.
    94 325ic 5-spd
    87 325is
    Oct 2008
    Belgium
    Thanks for the tip Mechanical Stig ,
    I didn't realise that's what the eccentric bolt is for !
    Seems real obvious now though
    I might try and bend it back with a grip wrench...
    I had a look, and I don't think it's possible to remove the
    clutch pedal without removing the pedal box assembly
    however, As a mechanical noob, I might be tempted to try
    and remove the pedal box, just for the sake of learning...
    If I can pull that off, It'll make me feel confident on tackling future
    problems the car trows at me
    Need to remove the steering shaft for that, with can't be to hard to
    find DIY info on..
    Also need to remove linkage between that brake pedal and brake
    master cilinder... Bolt B seems pressed in there.. no idea on how to
    remove it... Maybe I can just unbolt bolt A and that would free
    the brake pedal?
    Albuquerque, NM
    way too many
    All you have to do is remove the bolt #21. Easy task in place. No need to remove the entire frame.
    94 325ic 5-spd
    87 325is
    Oct 2008
    Belgium
    OK gonna give that a shot on Saturday
    Only had time for a quick look on Sunday, although not really clear from the real OEM parts drawing,
    the brake lever is mounted on the same bolt .. It seems like once you undo it, the brake pedal retention
    spring and bits might go flying all over the place.
    Getting that retention spring back into its place might be tricky with the pedal box still in place.
    Acces to clutch pedel parts is OK, brake pedal not so much
    Also limited space to the left with connector that's tricky to undo.
    ( really don't wanna break that )
    Gonna definitely try to just take out bolt first !
    Albuquerque, NM
    way too many
    It's not difficult to contain the spring. It won't go flying off. "I would rather swim naked across the Ganges with paper cuts on my nipples" . . than swap out an entire pedal frame.
    94 325ic 5-spd
    87 325is
    Mar 2014
    Quezon City, Philippines
    '89 535i/5, '88 735i/5
    That spring is fairly easy to replace. No need to remove the whole pedal box. Bolt one end of the spring to the pedal then the other end just sits there on the assembly.
    Oct 2008
    Belgium
    Ow OK, that's great news, I'll be one step closer to fixing up that car after Saturday!
    USA
    e34 540ia/e32 740il
    What Stigg said - DO NOT try to remove the pedal assembly, it is a nightmare. Just remove the long bolt that goes through the clutch and brake pedal. I also thought the brake pedal spring is under a lot of tension and that it would uncoil like crazy, but after you remove one of the spring arms from it's retainer hole you'll see that it will rotate a small amount before torsion is relaxed. It's not like a garage door spring
    Oct 2008
    Belgium
    Tanks I'll do that
    NYC & Long Island & So FL
    '93 740il '84 633Csi
    The key to attaching the hardline to the M/C is to first attach the hardline to the M/C, then the M/C to the firewall and pedal frame.
    Oct 2008
    Belgium
    Finished the whole deal !
    Re-bend and installed clutch pedal successfully, installed new clutch master and slave slave cilinder. Both were completly shut.
    Only need to flush the old dirty brake fluid now. Gonna be for next Saturday should all be good
    I tried attaching hardline to master clutch cilinder and feeding it through that way, however. Had little succes.
    Felt like I needed another pair of hands on the inside to assist guiding it in..
    So I separated the hardline from clutch master, placed clutch master it in it's place but, not screwing it to pedal box,
    only atteched it by it's feeder line ( to allow some movement ).
    Then hand screwed the hardline nut in clutch master
    After that securely screwed clutch master to pedal box and pedal
    Applied Loctite 577 for hydraulic lines on hardline nut ( and a lot of it )
    Managed to screw in the rest of it with a 11mm wrench that I angle grinded in half
    Probably not the proper way but am happy, it's in now !
    Thanks a lot for the help guys, really appreciate it !
  1. E32 SALE E32 manual pedal box (complete)
    By JW767 in forum Interior Lighting & Body Parts
    Last Post: 05-25-2010, 10:58 PM
  2. Clutch pedal - linkage issue??
    By Audi200tq in forum 1991 - 1999 (E36)
    Last Post: 04-21-2010, 11:34 PM
  3. Shifter/Linkages and Clutch Pedal Feel
    By DmcL in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-04-2007, 06:25 PM
  4. Squeaky clutch pedal fix....easy.
    By dbruce in forum 1992 - 1999 M3 (E36)
    Last Post: 05-03-2001, 11:56 AM
  5. squeaky clutch pedal.
    By gschomi in forum 1992 - 1999 M3 (E36)
    Last Post: 04-10-2001, 05:53 PM
