Results 1 to 25 of 43
Thread: What are the Dumbest Things BMW Has Done?
    Nov 2016
    Charlotte, NC
    '02 540i-6, '97 540i-6
    Let me start by saying I've had a lot of different cars, and that I've enjoyed my BMWs as much or more than any of the others. So I think BMW has done most things quite well. But with the benefit of hindsight, many miles, and years of experience, it seems clear that some things BMW did were really dumb.
    I have a short list of my own and will starting posting my items below. I'm curious to hear what others think.
    Nov 2016
    Charlotte, NC
    Long Oil Change Intervals --
    I'm not sure what led to this change. Was it because synthetic oil lasts longer before breaking down? Or was it because BMW started paying for the maintenance. (When we paid for it the intervals were short. When they started paying for it suddenly the intervals were much longer, and even "lifetime" for transmissions and differentials.)
    I understand that synthetic oils last longer before breaking down. But what about the filters that before had been replaced at 3,000 mile intervals? Was that never necessary? Can oil filters really last many times longer? Why risk it?
    And what about the stuff that filters don't filter out? Oil turns dark because of the carbon, dirt, etc. that it picks up and that is suspended in the oil by design. Does it help the engine to let that accumulate in the oil for 10,000+ miles before being changed? Of course not.
    For those of us with M62 cars, the clearest example of this mistake is the problem of clogged oil separators. I drove a '97 540I for 230,000 miles and that oil separator never clogged. The spec oil for that car was Rotella 15W-40 which I changed every 3-5,000 miles. (I aimed for 3,000 but wasn't always on time.)
    After that car got totaled I bought an '02 540i with 150,000 miles, and it had a clogged separator. Only then, when reading about others having similar problems, did I learn about this and how to attach an external separator.
    So how does a 1/4" gravity-fed oil passageway inside an engine get completely clogged? If it were just one car, I'd say it was bad maintenance (wrong oil, infrequent changes). But when it happens to a lot of us, I have to start blaming BMW for specifying the wrong oil change interval.
    Now I use good synthetic oil AND I replace it every 3,000-5,000 miles. Small price to pay to keep the inside of the engine clean and lubed.
    Jan 2016
    Ca
    2001 525it
    Having been in business for years the list would not be short.
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by R Shaffner View Post
    Free maintenance perhaps
    Nov 2016
    Charlotte, NC
    Internal Oil Separator (Deep down) --
    While I'm at it, having an oil separator deep down inside an engine, that takes many hours and several gaskets to replace. (The M62 example above.)
    Many later BMW's have external oil separators. I know freezing moisture can be a problem in very cold climates, but still an external separator seems better.
    Nov 2016
    Charlotte, NC
    Using Plastic Parts INSIDE an Engine or Transmission --
    I admire how BMW has been able to keep the weight down on its cars. As I understand it, the 5 series cars have weighed about the same since the early 1990's if not before. Pretty amazing considering how much more car one gets now, taller, wider, and longer. I know using more plastic and aluminum parts helps a lot with that, but does it make sense to use plastic for key parts that are inside an engine or transmission?
    Examples:
    The plastic timing chain guides in the M62. The M60 predecessor used a pulley in the valley between the cams. Clearly better. (Duh!) The successor, the N62, uses 2 gears on the crankshaft for 2 different chains. Also an improvement. Why would any engineer think plastic guides were a good long-term solution?
    A few years ago I fixed a clutch in a 318i for a widow in the neighborhood. Her late husband had given the car to her, and she couldn't afford what the dealer was asking to fix it. Actually the clutch and the tranny were fine. However, the clutch wouldn't work because a $2 plastic part in the bell housing had disintegrated. (The slave cylinder acts on an arm in the bell housing that uses the plastic part as a fulcrum.) So I pulled the tranny (in my driveway) to replace a stupid $2 plastic part.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Nikasil coating of cylinder walls. Total fiasco as US sulphurous gas damaged this coating to the point that many V8 engines were replaced on BMW’s nickel (pun intended)!
    Nov 2016
    Charlotte, NC
    Quote Originally Posted by MarcoZandrini View Post
    Right. Forgot about that one. Certainly high on the list.
    NW suburban Chicago
    hiss by my window
    That was quite avoidable too. Apparently the BMW engineers had never heard of the Chevy Vega which 25 years before suffered the same problems.
    The oil change interval is probably the worst because based on my experience, N62 and some N52 and basically all newer cars that followed the oil change procedure have valve stem seal failure. Have had a few cars in the shop that were one owner and they ignored the longer interval and their engines are fine.
    Beyond the obvious reaaons why thats bad, it has also tarnished bmw's reputation a bit when half the BMWs on the road are smoking... Because then other people on the road see the failures whereas a lot of oher failures can be kept from public view
    PRICE CUT on ALL FABRICS
    Nov 2016
    Charlotte, NC
    iDrive --
    I don't have a car with iDrive, and I'm so glad I don't. Since the 1970's, magazines like Road & Track had been talking up ergonomics and making the controls easy to find and use. The key point was to place the controls in different places and give them different buttons and levers, so the driver could find and operate them just by touch, without taking his eyes off the road.
    As driver's cars, BMWs had always been praised for doing it right. In my e39, I rarely have to take my eyes off the road to do anything important.
    Then BMW took a big leap in the opposite direction with the iDrive. I know that's not what killed the 7 series. SUVs did that. But I bet it helped. I know some drivers who hated the early iDrives in their cars.
    Nov 2016
    Charlotte, NC
    SMG --
    (I'm just guessing on this one, and I'm happy for someone who owns a SMG car to tell me what they think.)
    To me this looks like a cluster-____ from the start. A complex, problem-prone set-up that is between a manual and an automatic, but doesn't act like either? Really? What a marketing blunder that was! Did ANYONE in their research tell them that's what they wanted in a BMW?
    I've seen many nice used SMG cars going for deep discounts. Even if the transmission is working ok at the moment, prospective buyers shy way because it's not what they want and they're afraid of problems down the road.
    Sep 2009
    Lawrenceville, GA
    VW TDI and Dodge Dart
    The jack on the E36 is clever, easy to use, and folds up into a useless piece of sheet metal if you poke the car wrong while it's on the jack. After having to call AAA to get the car off a broken original jack, I went out and got a normal scissor jack.
    And don't get me started on the over-complicated and finicky convertible top that E36s used.
    Matt Cramer
    1997 BMW 328i convertible, 1972 Chevy C10 pickup, 1966 Dodge Dart slant six
    BMW - where "Why doesn't everybody build cars the way they do?" meets "Why can't they build a car the same way everyone else does it?"
    Feb 2018
    LANCASHIRE UK
    BMWE46 2004 Coupe
    Cheap Wiring Looms, Quality of ECU
    Aug 2016
    Upstate NY
    Honda S2000, VW Jetta TD
    Not that significant but....
    We considered an executive (Demo) totally loaded 335i for sale at a dealer.
    Carbon fiber look mirror covers!
    Really?
    Nov 2016
    Charlotte, NC
    Quote Originally Posted by gerry1000 View Post
    Really?
    Ugh! I guess when a company is trying to appeal to more buyers, it needs to build a wider variety of cars and expand options to cover different tastes. I see many BMW's that don't do it for me.
    Aug 2016
    Upstate NY
    I forget what the cost of the CF mirror covers were( $100 plus at least )
    I would have had to remove them before leaving the dealership
    Nov 2016
    Charlotte, NC
    I bought a Mini for my wife years ago. It had Union Jack covers. Made us think of Austin Powers. First thing I did was replace those.
    Nov 2016
    Charlotte, NC
    No Dipstick --
    Really dumb, in my opinion.
    What if someone repaired a bad oil leak and wanted to make sure the engine had the right amount of oil before starting it? Would he have to drain the oil to measure or replace it?
    Or what if there's a failure in the sensor/circuit that reads the oil level? Would the car shut down or go into limp mode? Would that disable the car?
    All that sounds absurd. How much money/effort does it take to keep a simple dipstick? This couldn't have been a cost issue. Just hubris and an overconfidence in one's new technology.
    Keeping the oil at the right level is just too important to deny owners such a simple and foolproof way to check it.
    Joppa, Md
    99 M Coupe,04 K1200rs
    No Dipstick --
    Yep, you gotta drain and refill with the correct amount of oil to check the sensor!
    It used to be impossible to lock my keys inside my older Bimmers, but now I can, not idiot proof anymore? ( still haven't done it by mistake,though)
    Nov 2016
    Charlotte, NC
    Hiding the Diagnostic/Performance Data from the Owners
    (This rant is directed at all car companies. I'll add it here because BMW, especially, should know better.)
    I like the way I can read the ODBI codes on my brother's 1992 e34. That old computer isn't sophisticated, the error codes can be like guesses, and the "stomp test" is cumbersome. But at least one doesn't need a special tool to learn what the car knows.
    Then OBDII comes along and buying a $60,000+ car isn't enough. One had to spend another $100 to get an OBDII reader/reset tool. What the hell? If the car is smart enough to know shit about itself, then why isn't that information made available to the driver, easily and immediately?
    A bunch of us are jumping through hoops, using old PCs and various old programs, just to get data from our cars. Why? It's MY car, damn it. I bought it. That's MY information. Why is it so hard to retrieve? (I know, BMW wanted to make money on the service and maintenance. Not a good enough reason for me.)
    Ever since the iDrive, BMW has had computer screens and a mice inside it's cars. Since then, a simple and better version of INPA should have been available on that screen. I agree that it should be harder to make important software changes, but when it comes to reading what the car knows, that should be standard equipment on every car -- especially on any ultimate driving machine.
    Jun 2017
    Los Angeles, CA
    BMW M3
    took the words right out of my mouth LOL
    Feb 2004
    Malvern
    05 M3, 98 euro M3, 01 M5
    Long OCIs
    lifetime diff/trans fluid
    EPS
    Turbos
    subscription based carplay
    dip stick removal
    using optical cables in a car
    eliminating manuals
    auto rev matching in manuals
    auto start/stop
    run flat tires
    eliminating spare tires
    plastic valve covers
    clutch delay valves
    4 door "coupes"
    "coupe" SUVs
    making 82,435,234,124 different body styles instead of making a couple (well)
    eliminating wagons
    only offering the remaining wagons in 4 cylinder awd automatic
    flash limits on ecus
    Joppa, Md
    Quote Originally Posted by ross1 View Post
    or Briggs and Stratton, lol, albeit, they're prolly just plain aluminum, start smoking in 5 yrs.
    Mar 2014
    Quezon City, Philippines
    '89 535i/5, '88 735i/5
    Or maybe they tried googling it, but spells it Chevy Wega.
    One thing BMW does, which is confusing and also somewhat dumb, is badging.
    M30B35 is 3.4L = badges E34 as 535
    M62B44 is 4.4L = badges E39 as 540 (could easily been a 545)
    Where's the consistency there BMW?
  1. the dumbest thing I've done in my 323
    By Greenfield in forum 1975 - 1983 (E21)
    Last Post: 04-18-2010, 09:37 PM
  2. What is the dumbest thing you've done to your car?
    By quattro PETE in forum 1996 - 2003 (E39)
    Last Post: 03-14-2010, 08:47 AM
  3. Dumbest thing I've done in a while...
    By dcroghan in forum 1992 - 1999 M3 (E36)
    Last Post: 02-21-2007, 05:22 PM
