Results 1 to 5 of 5
Thread: 97 1.9L Z3 Seat belt buckle switch
    Richmond, Virginia
    1997 BMW Z3 Roadster
    Hi,
    I’m unable to reset the airbag sensor? using the Peake R5/SRS2 tool. The code tables are Table 02, Code 10 Seat belt buckle switch, driver. Any thoughts on how to repair or reset the light.
    Thank you
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    I simply unplugged it and re-plugged it, shoving it in as hard as I could. I was lucky, that worked. Some say clean it with electric contact type cleaner. ..... If the Peake won't reset, you need a different tool. I downloaded the INPA, ( http://www.bimmerforums.com/forum/sh...xperimentation ) , but others found a tool for around $20 (much easier), sorry I don't have the source handy.
    Richmond, Virginia
    Quote Originally Posted by Liselot View Post
    Hi,
    Thank you
    Any suggestions on repair or replace the seat belt buckle switch?
    Feb 2012
    UK
    1998 Z3 1.9 5 speed
    Have you checked the wiring under the seat? If you're sure it's definitely the buckle, just buy a replacement unit from ebay and bolt it in.
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    ... Seat belt buckle switch, driver... Any suggestions on repair or replace the seat belt buckle switch?
    Maybe not the same thing, but my driver side buckle/receptacle stopped holding/latching the belt, so I replaced it. The airbag system did not care if I drove unbelted -- no warnings.
    http://forums.bimmerforums.com/forum...7#post27556907
    BMW MOA 696, BMW CCA 1405
  1. Z3 Seat Belt Buckle connector
    By dahrich in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 09-13-2014, 03:54 PM
  2. 1999 E36 M3 SRS Light (Seat Belt Buckle Switch) - SOLVED
    By dkim74542 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-11-2012, 06:20 PM
  3. Replies: 0
    Last Post: 09-27-2010, 12:21 AM
  4. SRS Seat belt buckle switch
    By brinkley in forum 1999 - 2006 (E46)
    Last Post: 06-21-2010, 11:34 PM
  5. FS: E36 & Z3 Seat Belt Buckle Receptacles
    By CarveRoad in forum Exterior Lighting & Body Parts
    Last Post: 08-29-2008, 02:22 PM
