Results 1 to 2 of 2
Thread: Trunk Light Does not Work
    Jun 2017
    Portland, OR
    2003 BMW Z4
    I noticed my trunk light was not working. I checked the bulb and the fuse and they are ok. I checked for voltage at the bulb base with none found.
    I read that the switch for the light in in the rear trunk latch. I removed the trunk latch and found a two wire connector (with brown wires) laying loose in the area. It appears to the be the same wire on the lamp holder.
    I am unable to find where this connector plugs into. There was no area on the latch mechanism for this wire to plug into.
    Does anyone have a picture showing where the connector is located or can tell me where to look?
    Harry
    1970 VW Sunroof Bus - "The Magic Bus"
    1973.5 911T Targa - "Smokey"
    2003 BMW Z4
    2009 MB C300
    Jun 2017
    Portland, OR
    2003 BMW Z4
    After testing, I verified the wire between the trunk release and the light was broken. I removed the flex connector between the trunk lid and the body. I found the brown with yellow stripe wire which provides the ground for the light was broken. Soldered in a splice and all is working again.
    Harry
    2003 BMW Z4
    2009 MB C300
  1. Trunk light does not work after replacing bulb
    By AndyG414 in forum Lighting sponsored by BAVToys
    Last Post: 11-24-2014, 10:42 PM
  2. Internal trunk LED light does not work :confused
    By kenshiny in forum 1999 - 2006 (E46)
    Last Post: 04-22-2011, 03:43 PM
  3. Trunk actuator does not work..
    By bimmer94525i in forum 1988 - 1996 (E34)
    Last Post: 01-28-2009, 08:53 AM
  4. HELP! LOCKED KEYS IN TRUNK. ACTUATOR does not work
    By eurotunerwerks in forum 1996 - 2003 (E39)
    Last Post: 04-18-2007, 05:36 PM
  5. Dome light does not work on drivers side .why?
    By vteckilla in forum 1983 - 1991 (E30)
    Last Post: 12-27-2005, 11:19 AM
