Results 1 to 12 of 12
Thread: Can't accelerate past 3500 rpm!
    Sep 2018
    Orange County
    1995 BMW 325i
    What's up guys I have a 1995 325i and I've been having this issue when accelerating I can't go past 3500 rpm, if I attempt to go past that and not change gear the car jerks, loses power and does so again until I change gear and repeats the same thing until I shift again. This go's on every gear so while I can still drive the car I'm peaking out at about 75 -80 mph. I've had the diff bushing changed because we thought that could've been the issueguy. But before I changed the diff bushing this would only happen every other day and on the days when it wouldn't act up I was still able to accelerate with no issues. But now that I have a new bushing it does it everyday. So at this point I'm not really sure what it could be. If anyone has had a similar problem or knows if this is a common issue please let me know. Thanks for reading the post
    - Completely stock other than a muffler delete and coilovers
    - 2.5L M50
    Jun 2010
    NY
    1997 328i
    Could be the speed sensor in the diff.
    Searched about "limp mode"
    Can also be bad fuel pump, be sure to do the filter if you replace it.
    Sep 2018
    Orange County
    1995 BMW 325i
    Thanks I'll definitely check that out . The speed sensor makes more sense now as the place I took it to for the bushing replacement didn't reconnect it and there's nothing plugged in right now. I wasn't sure if the sensor could have been the problem but now that you mention it I'll try that out
    Oct 2016
    Tenerife, Spain
    1997 BMW E36 323i
    Here's some info on a special engine limp mode when there is no speed signal.. I never heard of it, but at least some people think it exists.. It limits rpm to 5300 rpm though.
    Check it out here: https://www.bimmerforums.com/forum/s...Speedo-related
    What I'd also check is the crank position sensor.. Perhaps it isn't in great shape, or it isn't aligned well, and above 3500 rpm it loses sync..
    Also, if you downshift into a higher rpm range (4000 or 5000 rpm for example), then it also doesn't run well until you drop below 3500 rpm?
    Best to connect a laptop with INPA software and see what errors you can find..
    I've never before heard of an rpm-limiter at 3500 rpm with the speed sensor disconnected.
    1997 E36 BMW 323i
    (European) 275k km (171k miles), with following small mods:
    May 2012
    Central Wisconsin
    '94 325i, '93 325is
    It's not the speed sensor, you can drive around with no problems except a non working speedometer with it unplugged.
    It sounds like a crankshaft position sensor signal is failing at higher engine speeds. Any codes?
    '94 325i Sedan, Arctic Gray: UUC LTW FW, EVO 3 and DSSR, +.020 Maxsil pistons, ASC delete, Eibach shocks/springs, 16" contour reps 238k
    '93 325is Coupe, Schwarz, work beater 299k
    '89 325i Vert, Alpine White: 5spd swapped. Sold
    '04 Toyota Sienna XLE Limited AWD, In progress swapping to M50/G250, http://www.wibimmers.com/board/index...nna-25i-build/
    '05 Volvo V70 R, 6mt, mostly stock, kid hauler 200k Sold
    '85 Toyota LandCruiser: Lifted, gas hog. 205k
    May 2018
    Anchorage Alaska
    1997 M3 Sedan
    I’ve heard of this happening due to clogged cat. Car wouldn’t shift right and rev up
    May 2012
    Central Wisconsin
    '94 325i, '93 325is
    Quote Originally Posted by ArcticM View Post
    Easy test anyway, unhook the down pipe section and take it for a quick spin. It will be terribly loud but the exhaust can't fall down because the crossbar underneath is right under the down pipes.
    I have seen that happen on a gm 3800, it was just dead feeling, after an actual trip to Mexico. Must have found some poor fuel. I hooked up a vacuum gauge to the intake first and saw really weak vacuum so I unhooked the down pipe and then the vacuum was back and it ran well.
    SanDiego,Dallas,Miami,Orl
    Too Many
    When was the last time you changed your spark plugs? Also, have you tried disconnecting your MAF or checking for vacuum leaks? You still have the stock 20+year old coil packs? My RX-8 does this when the coil packs go bad (around every 15k miles-I love/hate the rotary engine)
    Too Many
    And I would check for the clogged cat problem-Ive been through that before as well and changed sooo many things before i disconnected the exhaust
    Current lineup: 99 BMW M3vert (project) , 05 Mazda RX-8, 04 Mercedes CLK320, 03 Chevy Express 1500 (work van).
    Previous rides: 07 Mazda RX-8, 92 BMW 325iNV, 94 BMW 325iC, 94 BMW 325i S50 M3 clone, 84 Mitsubishi Cordia Turbo, 84 Mazda B2000 lowrider, 88 Toyota Tercel, 88 Honda Accord, 93 BMW 318i, 95 Nissan Altima, 89 Toyota Camry, 95 Mitsubishi Eclipse GS-T, 93 BMW 318is, 84 Toyota Tercel, 96 Mitsubishi Eclipse GS-T, 97 BMW 528i 1JZ swap, 94 Acura Integra 4dr, 88 Toyota Corolla Wagon, 97 VW Jetta GLS, 86 Toyota Corolla AE86 4A-GZE supercharged engine swap, 94 Lexus LS400, 95 Isuzu NPR Turbo, 01 Suzuki TL1000R, 98 Honda CBR600F3, 99 Yamaha R6 and countless other dirt bikes and toys
    The Netherlands
    DE-spec E36 328i/M3 cab
    MAF connector fully fitted/locked in place?
    1998 BMW M3 3.2 Cabrio • Alpinweiß III on Schwarz • German spec • 1 of 12
    IG:
    Mar 2010
    Calgary, Alberta
    E36 STX
    There's a multi-page official thread regarding bogging and hesitation. Search for it.
    My own problem, which sounds similar, turned out to be bad coils. Took me almost a year to trace it though.
    Aug 2008
    St. Louis
    '88 engineless e30
    Did you ever figure this out? Having a similar problem.
  1. Wont accelerate past 2k rpm and 25 mph
    By carmeladam in forum 1983 - 1991 (E30)
    Last Post: 11-26-2016, 09:51 PM
  2. Engine shakes, idles hard but only after accelerating past 4500 RPM
    By ronniep in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 02-02-2015, 11:11 AM
  3. wont accelerate past 1500 rpm
    By 325i5280 in forum 1983 - 1991 (E30)
    Last Post: 12-07-2013, 08:43 PM
  4. Help! Can't accelerate past 2500 rpms's
    By ninetyseven1 in forum 1996 - 2003 (E39)
    Last Post: 07-19-2013, 09:16 AM
  5. Engine wont rev past 3500 rpm's?
    By ChadE30 in forum 1983 - 1991 (E30)
    Last Post: 01-08-2008, 09:19 PM
