:thumbsup::thumbsup:
______________________________________________
How to change the belt and belt tensioner on a BMW with an N20/N26 engine. Might be a similar procedure for the the newer B48 engine.
For 320, 328, 228, 428 models.
Tools required:
- Torque wrench for 14 ft/lbs
- 5 to 8" ratchet extension
- Ratchet
- 16mm socket
- E10 socket
- Flathead screwdriver
- Magnetic tool (optional but very handy)
- metal pin or ~4mm allen key to hold old tensioners tension
- Part number for the F30 328i is 11287618848 for the belt and 11287594969 for the tensioner
https://youtu.be/oN4acq0rd8U
Apex SM-10 & PSS | Injen Intake & Exhaust | Stoptech Steel Brake Lines | 4 pot Brembo front |
Hawk HPS 5.0 | RBF600 | Bootmod3 Stg 1 93 | ER Charge Pipe | ER TIC Pipe | Wagner Evo Comp 2
