A[IMG][/IMG][IMG][IMG][/IMG][/IMG][IMG][/IMG]1999 Red M3 Car was purchased as a street car by me in 2010 used a DE track car until 2015 when it was converted to a race car. Car is SCCA, NASA, PBOC, WRL, AER legal. I assume any other series you may want to race it in as well. Car has new fiberglass hood, trunk lid, carbon fiber sunroof insert all with fresh paint in May 2018, also painted the front bumper cover and mirrors. Had 3M clear bra installed on front as well. Also installed a new Hard Motorsports front splitter and Brooks Carbon Rear wing.Interior:
Race seat is a Sparco large size seat good until 2021. Seat on a slider I will keep seat if to big for you.
Schroth profit 2 belts for Hans good till 2021
Sabelt fire system new in 2017
AIM MXL2 digital Dash, and Display, with speed, rpm, water temp, voltage, oil temp, oil pressure, track map, and lap timer. Most tracks are preprogrammed, System is fully upgradeable to add more sensors and connect with Smarty Cam
Cool Suit
Helmet Blower
Light weight battery
pre wired with switches for additional front lighting
Kill switch new in May 2018
AMB Transponder
Suspension:
New for 2018 Motion Control 2 way adjustable with Remote damper set with rear coil over
800lb front spring, 450lb rear spring
Motion Control front camber plates
Large motion control suspension front and rear sway bars, new 5" adjustable aluminum links
Front strut brace
Rear strut brace
Drivetrain and Motor:
Car has a custom built M52, 2.8 liter motor that makes 266 hp at rear wheels, and 224 ft/lb on 91 octane pump gas on a DYNO JET.
Motor has fresh rebuild in 8/2018 new coated main and rod bearings, ARP head studs, new bottom end gaskets and seals, cylinder honing and piston rings, Cometic head gasket, custom valve springs, and solid lifter conversion kit.
CAT cams 282-274
custom pistons
minor porting
bored out throttle body
larger injectors
OBD 1 intake conversion to OBD 1
Miller war chip for ECU programming and tuning
New in 2017 Super Sprint exhaust headers to tail pipe, cat delete
new in 2017 Susa Oil cooler
new in 2017S54 oil filter housing
new in 2017 baffled oil ban
new in 2017 oil pump with upgraded suction tube
Mishimoto Aluminum Radiator with aluminum expansion tank
same sport silicon radiator hoses
AFE Cold Air intake
ARP wheel studs
New in 2018, 2 races on it BMW factory transmission ZF 5 speed
Achilles motorsports custom transmission mount
Clutch Master 03cm1-hds -AK clutch kit and light weight flywheel
Pyrotect 24 gal fuel cell, currently restricted to 19 gallons
I have a 3.46 LSD, 3.73 LSD or 3.64 LSD rear end your choice which one the car comes with both have cooling rear covers, and upgraded LSD with ramps. I believe they are three clutch. Will sell the other separately.
Brakes:
AP Racing Front big brake kit and two part AP rotors
Wheels:
New in 2018 Apex 17" x9" ARC-8 ET 30 offset in Anthracite
I have three additional sets available as well 2 sets have 1 day on them . However they are extra
Also have a brand new set of 17" Hoosier rains, and street rains for Endurance Racing
Car won GTO class at Road America in May 2018, and fastest lap of day one day. Fastest Road America lap with street tires is 2:33.4
Car has multiple wins and Podiums at WRL and NASA at Brainerd International Raceway. 1:39 on slicks
Sebring fastest lap on slicks 2:27.61
Cota Fastest lap on slicks 2:34
This car has won or podium at most every track it has been to.
Car weights around 2700#
I have tons of spare parts to sell separately or in a package to the car buyer for example, nitrogen bottle for dampers, new rotors and hard ware, apex wheels, new cv shafts, new front fenders, spare stock 2.8 liter motor, spare used transmission spare clutch master used clutch and lightweight fly wheel, front A arms, hoses, hardware, stainless brake lines, bushings, metal water pumps, radiator, and tons of other stuff.
Car is $19,999.00call or text me for pics or info.
Andy 218-349-8230
I'd be interested in the 3:64 diff if it's available.
