Results 1 to 8 of 8
Thread: Factory radio wiring
    Vermont
    81 320i, 98 318ti
    I am putting two channel factory/dealer instaled Blaupunkt radio/cassette in my 81 320i. Factory wires including the fader switch are there, so it is easy to plug it all back in.However, speakers in my car are aftermarket 4ohm 35w units and I am concerned that they may damage the internal amplifier of a factory radio.
    I have read that the factory speakers were 8 ohm but not sure if it only applied to 2 speaker systems in older Bmw's (2002's).
    The question is- does anyone know if bmw's "common ground" wired speakers are wired in series or in parrallel? Anybody is using 4 ohm speakers with the factory radio?
    My understanding is that if I have two 4 ohm speakers per channel wired in series, the amp will have the equivalent of one 8 ohm speaker per channel connected. I am hoping it is the case, but wanted to ask since I do not have the wiring diagram handy.
    Thanks,
    Max
    May 2015
    Chicago, IL,United States
    1977 BMW 320i
    I have 4-ohm speakers running through factory wiring (including dash-mounted fader), and a 1975 (approximately) Blaupunkt Frankfurt. It all works fine, but I had thought that 4 ohms was the same impedance as stock. At one point, I made a diagram of the speaker wiring (I had to re-connect the fader), but I can't find it immediately. If I can find it, I will post it.
    Jul 2010
    San Jose, California
    E21 320i, E30 325i
    Here is from the '81-'83 ETM
    '81 E21 320i / '90 E30 325i / '̶9̶2̶ ̶E̶3̶4̶ ̶5̶2̶5̶i̶t (sold) / '15 Toyota XW30 / '̶̶8̶0̶ ̶E̶2̶1̶ ̶3̶2̶0̶i̶A̶ (sold)
    Vermont
    81 320i, 98 318ti
    Thank you, I have the same radio (bavaria s) and glad to hear that 4 ohm speakers work fine. I checked Bmw etk and it hows both 4 and 8 ohm speakers.
    The reason I am asking this is because while researching radios I found that older blaupunkts are supposed to have one 8 ohm speaker per channel but I suspect it only applies to 1 or 2 speaker systems. Perhaps my theory that e21's wired in series using four 4 ohm speakers with only 2 channels (8 ohm each because of 2 speakers on each channel).
    Max
    Corona California
    79 320/6 81320i 65malibu
    Max a little of topic - can you get a picture of the radio mount?
    Mine has been out of the car forever.. There is a steel bracket that holds the back of the radio correct?
    Vermont
    81 320i, 98 318ti
    Quote Originally Posted by amarino View Post
    That is very helpful, thank you!
    Quote Originally Posted by OLD MAN View Post
    Daryl,
    I do not have that bracket for the A/C console but I have to look in my spare parts, I may have it. I believe there supposed to be one as there is a stud on the back of the radio and 10mm bolt where the AC evaporator sits. However, it will not go anywhere without that bracket.
    What exactly you are trying to figure out? What radio do you have, they mounted slightly differently depending on the radio model.
    Max
    Feb 2009
    District Nine
    sold 78 BMW 320i
    Here's a copy of the whole electric manual for the '81-83 320i.
    http://www.findmymerchant.com/images..._1981-1983.pdf
    Tbd
    Vermont
    81 320i, 98 318ti
    Thank you, that is very helpful!
  1. E34 WTB E34 Factory Radio Wiring Connectors
    By brob87 in forum BMW Parts Wanted
    Last Post: 12-02-2014, 01:33 PM
  2. Grounding Factory Radio? ver. Wiring Diagram
    By Roofus in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 08-10-2011, 04:54 PM
  3. hello, Im new here..how do i put subs in with factory radio?? wiring?? 06 325ci
    By ejis4lsu in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 03-04-2010, 01:47 AM
  4. Wiring scheme for E36 M3 factory radio
    By Vader M3 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 04-16-2006, 09:53 AM
  5. Need wiring harness for factory radio...PLEASE help!!
    By turnerjd in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 11-28-2004, 08:32 PM
