Results 1 to 16 of 16
Thread: spring compatability
    Wichita Falls, Texas
    1997 BMW Z3 2.8
    Good morning. I have a 1984 325e lowered on bilstein sports shocks and H&R springs. Tired of the rough ride. I've found a 1988 325 IC in a salvage yard, and am wondering if the springs on the 325 IC will fit my car. Checked with real OEM and the part numbers for the springs are different for the two cars. Thanks for any input or ideas. John
    Mar 2012
    Hopewell Junction, NY
    1987 325iS...edan
    The number is different because they use stiffer springs than a sedan. Which H&R spring?
    Interested in vintage cars? Ever thought about racing one?
    Info, photos, videos, and more can be found at www.michaelsvintageracing.com!
    Elva Courier build thread here!
    Sep 2014
    KS
    e24e30e36e39e90
    You are so lucky to find an e30 vert in a yard. so many vert specific parts. I had one locally that I went to several times, then one day it was gone. Kicking myself hard for not harvesting more of the vert specific stuff.
    Jul 2018
    Atlanta
    1992 e30 318i vert
    It probably won't work. I have a 91 vert and got 2 sets of used E30 springs without really thinking - one set from an E36 M3 sedan and another supposedly from a coupe. I got the rear springs on and it looks like a monster truck - the fronts just will not fit period. I've read the vert is either 200lb or 200 kg lighter than a coupe (I don't know about the sedan) and clearly uses softer springs. Putting teh vert springs on anything other than a vert will overload the springs and your ride will probably be worse but in a different way than it is now. I think it is best to buy exactly the springs you need for your vehicle - that is what I learned.
    1997 BMW Z3 2.8
    Thanks to those above for the good advice and information. Of course I was trying to get the job done on the cheap, and forgot that springs come in differing degrees of stiffness.
    323i E30's Avatar
    323i E30 is offline ⅂!ʈө !ƨ l!ʞө ɐ ʇөlөbµouө
    Jan 2013
    Europe
    M52 E30 touring & E91
    Quote Originally Posted by Texaslonghorn1 View Post
    (...) I've read the vert is either 200lb or 200 kg lighter than a coupe (I don't know about the sedan) and clearly uses softer springs. (...)
    The vert is actually the heaviest E30 possible.
    ^ true story
    D̶i̶b̶s̶ ̶o̶n̶ ̶t̶h̶e̶ ̶E̶2̶1̶
    Jul 2018
    Atlanta
    1992 e30 318i vert
    I stand corrected on the weight then. But the Monster truck stance is 100% accurate because those springs are sill on my car today. I won't be taking them off until I get new correct springs.
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    E36 m3 springs lower a regular e30 about 3/4 of an inch. I have ran those before
    No e30s again.
    CANTON, OHIO
    TRIUMPH tr250,tr6, bmw 325i
    My 1985 325e has E30 m3 oem bmw brand front springs and HR oem sport rear springs, koni sport adjustable shocks all the way around giving just the right amount of lowering, as much ride comfort you can get with non original suspension,
    1997 BMW Z3 2.8
    All good information above. Anyone know if H and R OEM Sport springs are compatible with Bilstein Sport shocks? Those springs are purported to lower the car only about an inch and come closest to a stock ride. I would like to use the Bilstein sports that are already on the car.
    Dec 2005
    No e30s, again :(
    Yes, the bilsteins work with those
    No e30s again.
    Jan 2017
    USA
    E21, E46
    Yes they are compatible.
    Sep 2018
    Colorado
    91 E34 M5, 90 325is
    Quote Originally Posted by superj View Post
    Not to hijack, but how do these ride?
    Dec 2005
    No e30s, again :(
    Rode fine when i had them. Good for a fun daily and worked ok for autocross.
    No e30s again.
    1997 BMW Z3 2.8
    My head is still spinning a little. Real OEM lists a gazillion different parts numbers for E30 springs on different models. But I am getting the sense that all or most of them fit any E30, but spring stiffness varies with the model of the E30. Does that sound about right? I'm tempted to drive to Dallas and pull the front and the back springs off a mid 80's 325 vert that is sitting in a yard, buy some oem replacement shocks and call it a day. What do you guys think? John
    Dec 2005
    No e30s, again :(
    you can. they do indeed all fit any e30 but have some higher or lower spring rates. there is a guy selling e30 m3 springs on craigslist in san Antonio. you might be able to get him to ship them to you for hardly anything, just have to ask him. those would be better than convertible springs because they would lower you a little bit instead of possibly raising you up a little
    No e30s again.
  1. 95-96+ Spring compatibility...
    By rommelrules in forum 1992 - 1999 M3 (E36)
    Last Post: 11-04-2009, 01:13 AM
  2. Are M Coupe springs compatible with regular Z3 Roadster?
    By luciano136 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-20-2007, 02:23 PM
  3. e36, e30 springs compatibility
    By beaminhard in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-22-2006, 04:46 PM
  4. Help: rim and spring compatibility
    By EvyKat in forum Wheels and Tires
    Last Post: 08-07-2006, 10:42 AM
  5. Spring compatibility
    By BTSG325i in forum 1991 - 1999 (E36)
    Last Post: 07-18-2004, 02:13 AM
