So my summer run flats have much more tread wear on the rear wheels than the front. What’s the reason ?
2013 BMW 320i xDrive (F30)
~145,000kms
How does your alignment look? The rear has a lot of adjustment possible. That or something is bent.
-Abel
- 2000 Z3: Many Mods.
- 1999 S52 Estoril M Coupe
- 2016 Mini Cooper S
I’m not sure about the alignment. All four were put in at the same time so not sure why rear tires have more wear. Could it be because of xDrive or something ?
~145,000kms
It's much more likely to be an alignment issue. xDrive doesn't significantly change the rear, and would actually improve tire wear by having all 4 wheels contribute to acceleration.
Also make sure all 4 tires are the same brand, model, and size. They MUST all be the same. Correct inflation pressures are important too.
-Abel
Even with xDrive, your rears will wear twice as fast or more if you drive aggressively, esp. on launch. xDrive is still 60 rear/40 front traction distribution. On my last xDrive, I replaced the rears twice more frequently than the front and the front still had tread, but was worn on the edges due to hard cornering.
Current Car (delivered 20/10/21): 2021 G80 M3; 6MT; DravitGrau/Kyalami Orange/Black Extended Merino; Permium Pkg (ZPP); 826M bicolor wheels; Black M Compound brakes; Sunroof (yes no CF roof)
(more pictures here)
Previous Cars: 2018 F30 340ix 6MT Msport(Dec 2017 - Sep 2021); 2013 F30 335ix 6MT Msport (Nov 2013-17); 2011 e90 328i 6MT ZSP (Aug 10-Nov 13); 07 e90-323i ZSP (May 07 - Aug 10); 97-318ti ZSP (Feb 97 - May 07)
"Mit der Dummheit kämpfen Götter selbst vergebens", Friedrich von Schiller -- "Life is simple, people make it complicated", Me (About me)
I had a 2008 535i (non-xdrive) and it went through rear tires twice as fast at the fronts. I also had the sport suspension. The wider rear tires tend to wear twice as fast as the fronts. The nature of that beast and normal for that set up.
