Results 1 to 25 of 29
Thread: Another Rack and Pinion Pipe Dream Thread
    May 2014
    Springfield OH
    1993 525i 1995 553i
    I figured I should post here about what I have been working on since I am sure there are members in this board who would be interested in this or might be able to provide some good insight and ideas. Lately I have been stuck on doing a rack and pinion swap to my 95 525i since this needs to be the ultimate driving machine and a steering box does not cut it. I am going R&P for other reasons, but I would still prefer the feel of it anyways. Before I dive into my current project I will preface this by saying that this rack and pinion project does coincide with an LS swap so I in theory have a bit more freedom to alter things a stock car may otherwise not be able to. However with the route I have taken, I do believe it is possible that my planned setup may work on a stock E34 .
    First thing was to determine which rack to use. Being a rear steer, it really limits the racks I can choose. I found a few racks that have the same inner tie rod pivot points at about 24" . There are a lot of GM racks that meet that criteria, Cavaliers, Sunfires, GTOs, LeSabers, etc. I did notice a lot of the GM racks shared a lot of the same architecture. But the big issue with those is the transfer tubes come out the front where it would hit the subframe and go over the top of the tube, which I will explain why that is an issue in my next point. But ultimately I have decided to skip the GM racks and go with a MKIII Golf rack that is ZF built. The lines come out the back and also stay low so no overhead clearance issues supposedly. Also when it comes to the steering ratio, the GM racks were all about 2-3/4 turns lock to lock and the VW rack was a tad under 3-1/4 turns. The linear travel of the stock center link was about 6-1/4" , the GM racks had about 5-1/4" of linear travel, and the VW rack has 5-1/2" of travel. So there will be a slight reduction in turning radius, less so with the VW rack. Not sure by how much however.
    Picture below. Stock center link, mid 2000s LeSabre, 2001 Cavalier
    Picture below, Golf Rack
    Getting the geometry correct is going to be the biggest obstacle to overcome. I started by measuring the stock center link location. I measured it from some parts of the frame to the center points. The easy part is how far back to set it, the difficult dimension to keep will be the height. The stock center link dips down below the oil pan and comes back up towards the outside. Putting the rack in the exact location it needs to be will be putting it in the oil pan. This is where that overhead clearance issues arised with the GM racks. The closest I got was 1" below the stock location and that was fairly close to the oil pan and I removed the transfer lines to get it there.
    I tried making new lines that were going to be routed to go under the rack but I can easily see an issue where they might get busted on a bad road since it does sit fairly low, and they use some weird fittings that I cannot find for sale.. The mounts on a horizontal mount rack will end up sticking below the sub frame making a very crucial part of the safe operation of this vehicle vulnerable. Not good.
    The GTO rack has a vertical mount so it would be better and the lines get routed below the rack not on top but the lines look like they would stick out more than I feel comfortable with. That is why I decided to go with the VW rack. The lines come out the back and do not go above or below the tube so it would allow me a little more flexibility to get it in position. I have not tried putting the VW rack up yet but I will play around with it this weekend.
    I doubt that I will make up the 1" so that brings me to where I am currently pondering. I am thinking of flipping the tie rod ends around to make up the difference. I know it would be better to have all the pivots (control arms, tie rods, etc) on the same plane but I do not see that happening. I am thinking of drilling a press fit hole through the tapered hole in the steering arms and making a separate bushing with the tapered hole so I can swap it around as I experiment. I do potentially see an issue with flipping the rod end. It almost looks as if it could potentially contact the wheel if it was fat enough.
    Tie rods will be easy I hope. I am hoping some kind of off the shelf inners work, but I can order a custom set to certain dimension if needed for about $45 a piece. For the outer I need to figure out if the E34 is a 7 degree or 10 degree taper for the cone pin. Anyone know what it is? Steering linkage, I don't know but I am not too worried about that. I will get there when I get there. So that is where I am at, hopefully this will prove out and benefit us all. I know it has been done before but all the old threads the pictures are gone, the threads just died, or was very vague. I hope I can provide as much info to help anyone else out wanting to do this. I will continue to update as I progress with this and hopefully get this set up right.
    95 E34 553i6 LS TR6060 Project
    93 E34 525iA Beater with no heater
    VANOS kicked in yo!
    Nov 2017
    Hungary
    1984 BMW E28 535i
    Following...
    1996 Orientbraun BMW E34 532i Touring
    STANCE | WORKS
    Zionsville, IN
    93 740i, 84 533i
    I may use a UK version E39 rack, flipped over.
    Black on Black 740i - 10/92 build date, 225,000 miles.
    Delphin on Cherry 533i - 4/84 build date, 136,000 miles
    Black on Black 328i - 3/96 build date, 185,000 miles - Sold
    2008 Porsche Cayenne GTS
    May 2014
    Springfield OH
    1993 525i 1995 553i
    Quote Originally Posted by Avec View Post
    I was thinking that but getting one would be a real PITA here and I am trying to make this car as serviceable as possible.
    VANOS kicked in yo!
    NW suburban Chicago
    hiss by my window
    I will say this once and then STFU.
    WHY has nobody tried simply attaching an E39 subframe? The geometry is already worked out, screwing one into place cannot be that difficult.
    Over and out
    May 2014
    Springfield OH
    1993 525i 1995 553i
    Quote Originally Posted by ross1 View Post
    Over and out
    I think it would be a great idea but I do have concerns over that. I tried looking into that but not a lot of info out there on that and I am already too invested to mounting this LS to the E34 frame that I cannot just throw it out that easily, but that is my personal problem. The GTO front sump oil pans are not cheap, I do not want to design more mounts for a different subframe and I got the F30 calipers to work on the E34 knuckle.
    Another potential issue is the geometry when it comes to the strut. The E39 strut could be wildly dofferent than the E34 and a combo of E34 strut angle with E39 control arm geomotry could really screw woth the roll center in a negitive way. I do not think it would mess woth bumpsteer that much however. Again, I do not know how similar they are so it might not change at all for all I know.
    Next issue is converting the knuckle to front steer. So either modify the E34 knuckle to be front steer, figure out how to mount E39 struts to the E34 body, or figure out how to make an E39 spindle bolt to E34 struts.
    But again these could be non-issues beyond just mounting the subframe to the E34, I just simply do not know for sure.
    VANOS kicked in yo!
    Mar 2006
    West Haven, Ut
    E34 Touring
    I swapped a caviler rack into mine for oil pan clearance. I had to mount mine a bit lower and had to do some work on the spindles to get the bump steer reasonable. I used an H2 pan and wish I had gone GTO. I am currently swapping to the Holly pan to get a little better sump clearance after the mishap.
    Mar 2006
    West Haven, Ut
    E34 Touring
    Here is my rack mount. sorry for the photobucket links
    May 2014
    Springfield OH
    1993 525i 1995 553i
    Quote Originally Posted by flynfrog View Post
    Some of your posts, actually prompted me to look into the Cavalier rack, I did not know you were still active. So what did you do to re-work the spindles to adjust for the bump steer and what tie rod ends did you use?
    VANOS kicked in yo!
    Mar 2014
    Quezon City, Philippines
    '89 535i/5, '88 735i/5
    How about the bump steer correction plates sold by AKG?
    May 2014
    Springfield OH
    1993 525i 1995 553i
    Quote Originally Posted by cirrusblau View Post
    Ideally the control arms and the tie rods need to be parallel, that kit will lower both the pivot of the tie rod and the control arms on the knuckle. What I need to do is lower only the tie rod ball joint at the knuckle.
    VANOS kicked in yo!
    CT
    '94 530iT LSx/T56
    Over and out
    Someone did. Its a Calypso car with an LSx swap in it. He used the entire i6 e39 subframe and modified it or made adapter plates to the e34 "frame". Looked quick and cant seem to find his info but will keep an eye out and report back.
    -Alex
    Akron OH
    e34, e30 x2, Unimog
    Over and out
    In my opinion its basically a waste of effort.
    Every vehicle is an assembly of packaging compromises, taking the compromises from one chassis and adapting them to another just compounds the issues. The geometry is really fairly simple.
    Quote Originally Posted by AHenry014 View Post
    Quote Originally Posted by XCRN View Post
    I've had a rack setup in my e34 for 6 years now, and have a new revised version in a Alex's ^^ car for 3 years. It really changes the way these cars drive.
    Shoot me a message, I don't forum too much these days. Looks like you are semi local too.
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    First I hear of the E39 subframe idea. That would imply E39 control arms and struts, which are aluminum, which alone is a worthwhile upgrade. I'd be very interested to see what it took to work.
    Depending on engineering resources available, I'd look into offset inner tierod ends, where the ball mounts higher than the rack, mimicking the E34 center link design.
    Mar 2006
    West Haven, Ut
    E34 Touring
    You are quite a bit higher up than I am. Wish I would have gone GTO pan. Initaly I got some rod ends off of a fiero I think. I think these are it. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    I didnt like the bump steer so I drilled through the taped and went to heim joints. The issue will run into is that the GM rack is an oddball thread. You might try to the Fiero rod ends first though.
    I think its a M14 1.5
    I got my parts from
    this place https://www.ebay.co.uk/usr/mcgillmot...p2047675.l2559
    The attachment I hadn't tightened everything up yet. So they don't sit that low with that much bending on the bolt. I got good rated bolts from mcmaster. I also considered cutting and welding the spindle but I was concerned about keeping everything straight. I haven't really had any issues with the current setup. I do seem to get a weird roll steer at low angles and high body roll (freeway curves). I think a stiffer ARB will take care of this. Speaking of that you will probably run into an issue of the ARB wanting to occuppy the same place as your slightly lower steering. I just cut and extended the linkages about an inch. This probably lowered my roll stiffness but I wanted to do burnouts.
    Sorry if this is somewhat brain dumpy but if you have any questions and I dont log in my email is my username at gmail
    Good luck on the project.
    Mar 2006
    West Haven, Ut
    E34 Touring
    I also forgot the horn grounds through the steering shaft so it might not work depending on what you end up with to make the shaft work.
    May 2014
    Springfield OH
    1993 525i 1995 553i
    Still working on this. I got a real asinine plan for the tie rods that involve a Honda Accord inners, stock outers, and some 7075 Aluminum. I got the subframe out after many hammer blows so I could mock things up even better. So I got some mounts drawn up that will be welded to the sub frame made out of 1-1/2 square tubing and some metal strips. I just bought a new AC/DC TIG welder so I am looking forward to doing this.
    The amount I have the rack dropped compared to the center link allowed me to just lip over the steering arm and it will theoretically line up perfectly.
    During my measurements the control arm pivot points chassis side are about 25" and 26.5" and it seems all pivot points on the knuckle are inline. It seems like there is built in bump steer from the factory given the center link pivots do not fall within the plane of the control arm pivots. I am not sure how much bump steer there is from the factory so I might just bolt all the stuff back together and find out to verify my theory. If I am correct, I will need to push the rack and pinion pivots out to abut 25-1/2" to 26"Also, I noticed on the sub frame where the control arms mount. There are 2 holes in the tabs, is the outboard hole there for no reason or is it a way from the factory to change the geometry?
    VANOS kicked in yo!
    ATX
    Sundry old Grrrrmans
    The outer holes are for the E32 (shared subframe). There are some threads about E34 owners using them to mess with geometry but it’s not ideal.
    - Brent
    www.angry-ass.com
    Quote Originally Posted by danespann View Post
    Every E34 needs the same things in the end.
    May 2014
    Springfield OH
    1993 525i 1995 553i
    Quote Originally Posted by BleedsBlue View Post
    I was thinking that was the case, did not plan on doing that but I could easily see somone (including my self) using the wrong hole. I was just really curious about that.
    VANOS kicked in yo!
    ATX
    One must always be careful when using the wrong hole.
    - Brent
    www.angry-ass.com
    moroza's Avatar
    BFE
    E34T
    Not to go too off-topic, but does an E32 thrust arm crossmember also share geometry (hole-to-hole distance... also important... ) with the E34? I wonder about swapping to an early rubber-mounted 750iL crossmember for extra NVH reduction.
    Welded knuckles seem spooky. Though not as bad as what's in post 15.
    May 2014
    Springfield OH
    1993 525i 1995 553i
    Quote Originally Posted by moroza View Post
    Agreed and they will not be permanent, though this was not welded using your typical at home welder. It was welded with a 400 amp industrial welder. They are welded upsidown only for test fitting all the stuff. I will be making a whole new lower knuckle from scratch based on the new locations if all works out.
    VANOS kicked in yo!
    May 2014
    Springfield OH
    1993 525i 1995 553i
    Was finally able to get back at this project. Been hunkering down paying off all my debts years in advance so I should have a little more freedom to put towards this. I think I have a great start on this.
    I was able to make some mounts for it and I am trading welding work from a co-worker for powder coating work. So for now it is just tacked. I am going to incorporate the rack and pinion mounts with the LS mounts since I need to redesign those. The oil pain will hit the R&P with the old mounts I made.
    I made a quick concept of the tie rod which utilizes a 98 V6 Accord inner tie rod and a stock E34 outer tie rod with the LH thread. The connector is made of 7075 Aluminum and I think for the real pieceI will enlarge at the ends of where the threads are and have it taper off towards the middle to clear the control arm. As is it did not touch the control arm at any position around it's approximate real world suspension travel, but it got REAL close in some areas.
    I tried my best to test for bump steer. This is where I could use some opinions on the results. The stock E34 wheel center to fender height it 15" (at least on my stock 93). I will probably lower the car with a set of Eibach springs I got so I set the wheel center to fender at 14" as my base. Below is my setup. I set the square at a 90 degree angle, parallel with the lower caliper mounting tab. I marked a spot on the tab and where it was in relation to the square which was at the 14" mark. I marked 2 more spots at 1" intervals above and below, so 4" total. I raised and lowered the suspension and observed the caliper mount move in relation to the square.
    This is the video of the suspension travel. When the suspension is moved up (compressed, bump, whatever) 2" from the base line it hardly moves, but 2" below (droop, rebound, whatever you want to call it) it swings out a lot.
    Can't figure out how to imbed video so heres the link.
    https://www.youtube.com/watch?v=nICgq4ZjOlU
    VANOS kicked in yo!
    Mar 2011
    Neverland
    E34 525i
    Thats pretty normal especially at that level of stretch. If its a big deal for you a set of coilovers that limit drop should erase that concern
    May 2014
    Springfield OH
    1993 525i 1995 553i
    Quote Originally Posted by Hofmeister View Post
    If it’s normal that is good for me. I figured the only time I am drooping that much is when I am jumping dukes of hazzard style or cornering. Atleast where it is pulling it will be turning towards the corner I am in.
    VANOS kicked in yo!
  1. The "Armen's Pipe Dream" Thread
    By Dark Helmet in forum 1988 - 1996 (E34)
    Last Post: 01-24-2005, 04:01 PM
  2. Rack and pinion help......
    By John540i in forum 1983 - 1991 (E30)
    Last Post: 09-19-2003, 07:15 PM
  3. Another E30 M3 vs. Modern Cars Thread
    By GreekDriver in forum Off-Topic
    Last Post: 08-07-2003, 09:35 PM
  4. The Dream Thread, Revived
    By LinearX in forum Off-Topic
    Last Post: 01-30-2003, 08:49 PM
